96 Vortec stumble/miss after changing intake gasket UPDATE PROBLEM SOLVED
Discussion in '1992-Present Chevy & GMC models' started by MOABDADC22, Feb 27, 2003.
  1. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    I posted this in the garage too, but figured maybe you guys/gals could help.
    I just got done changing the intake gasket /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif on my 96 Tahoe (5.7 Vortech.) Now it has a very noticible miss. The "Check Engine" light flashes on/off at a steady rate.
    All hoses/wires are in the correct spot. I have sprayed the intake with carb cleaner to check for a leak with none found.
    I did get the distributor 180 degrees off on the first attempt (DUH....) but pulled it and put it in the correct spot. I am pretty sure that the base timing is set right at 0 degrees. Is this correct?? I guess I could go fire it up and turn the distributor a little and see if that cures it. If it does.......how do I clear the trouble codes??
    Any help would be greatly appreciated. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  2. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Re: 96 Vortec stumble/miss after changing intake gasket HELP
    I forgot to add that the engine runs pefectly smooth for about the first 2-3 seconds after I start it, then it develops the miss.
    It ran like a top before I changed the gasket.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    With the engine running - grab some of your spark plug wires and move them around (not disconnect them, just move them around) - see if that does anything. You may have some wires laying on eachother and the charge going through one wire get's crossed with/taken by another wire. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif Worth a try. Also, re-check the placement of the sparkplug wires on the cap. If two of them are mixed up, you'll get miss-fire like you described. I know you said you have them right - but just check again *trust me* /forums/images/graemlins/smirk.gif
  4. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    OK, I scanned the codes with an OBDII and got P0102 (Mass Air Flow sensor Circuit Low Frequency) and P0304 (Misfire on #4 cylinder). soooooo....I am thinking that the # 4 intake gasket area did not seal/seat good enough and that is causing the MAF to detect air leaking in and then causing the #4 to misfire??
    Am I way off base or what??? I will probably buy another gasket and start over. (At least now I know that I can change the gasket in under three hours) /forums/images/graemlins/thumb.gif
    Thanks for the replies /forums/images/graemlins/deal.gif /forums/images/graemlins/deal.gif.......keep them coming since I will read them again in the morning. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I'm starting off here ignorant to your skill level so bear with me. The Vortec engines use a SPFI(sequental port fuel injection) system which is diffrent than other GM style systems in that your injectors are firing with the firing order. The other systems fire a bank of injectors at a time not just one. Anyhow your codes tell me a few things. I would start off with the basic(easiest) stuff first. Make sure your ign. wires and injector wires are all connected to the correct cylinder. I think your good here, but check it anyway. One word of advice, do not use carb cleaner on a running feedback fuel injected motor, use intake air fuel injection safe stuff. /forums/images/graemlins/thumb.gif
    With the style of gasket the Vortecs use I'm not surprised you couldn't get a change, however I don't know how bad the miss is either /forums/images/graemlins/eek.gif. The torque on the intake bolts if I'm not mistaken is like 15-20 ft-lbs. Not alot to get them tight, so keep this in mind as well. When/if you remove the intake again look for hair line cracks in the plastic (just to let you know your doing a good job, and found it) /forums/images/graemlins/thumb.gif
    Hope any or all of that helps you. /forums/images/graemlins/thumb.gif
  6. finnd
    finnd Registered Member
    Dec 27, 2001
    65
    Northern Virginia
    verify all the fuel injectors are hooked up correctly and working. You may get a gassy smell if one is dumping. Check the plug for that cylinder as well to see if it is getting really fouled.
  7. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Ok, I was right....the intake gasket was not sealing on the #4. I think the gasket slipped down and out of alignment when I lowered the intake. All fixed now.
    How do I clear the trouble codes now and get the check engine light off?
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    disconnect the battery
  9. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    Its an OB2 com so youll have to go hook it up to a scaner to clear the troble codes if it were OB1 then yes the battery trick could work but its different with OB2
