97 C-1500 with 4L60E, no reverse or overdrive
Discussion in 'The Garage' started by R72K5, Jan 10, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    we got in a 97 c-1500 ext cab 2wd with 5.7L and auto overdrive, reverse and overdrive are out, it will drive, it started this about a week ago, fluid is great shape bright red no bad smell or anything
    its got 141k on it babied since it was new he wont evne smoke in the truck, nothing not a scratch on it anywhere, nothing
    yards and trans guys say no known issues with these trannies, so no reason for it to be out
    what do you think to check first before yanking tranny ?
    thanks
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok looked closely and its 2 quarts low, cold, added those and it still has no reverse,
    noticed that it has a whirring noise in park and reverse and neutral only, not much- if any- louder than the idle speed exhaust sound(nice good cat backs)
    put it in drive and the noise goes away, its like something is spinning in trans but catches in forward gear and quits spinning
    any ideas ?
    who to ask ?
    thanks
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i can't think of any reason for those to be not working, probably time for a rebuild.
    are there any codes? you'll probably have to go to auto zone to pull the codes. if there are any codes for the tranny i could look them up and see what i can find.
  4. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    tranny info
    sounds like the low/reverse clutch pac. or possible pump, the pumps wave a powder metel vane setup that crackes and brakes. and for the tranny shops saying no known problems , thay are full of s#%t and were blowing smoke up your u know what . the 4l60-e is just a updated version of the 700r4 and its all comp controled shifts , thats all. and with 140k on it just reman it and get it over and done with. if you want the easy and decent price way out . then go to the local parts store and geet a reman and it comes with a converter and a can of cooler line flush to get the crap out of the lines . try this and good luck.:laugh:
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    no idea on codes and all that and cant be driving it with the troubles its got, the trans shop says its converter or pump most likely, we are pulling out the trans in the AM, then i got to cut the 3.42 rear axle and remove rear hatch and front seats all from an 87 camaro after i drive it to here, and find a driver side door for the 82 k10 project in a local towing yard for my stepdad, and take the 97 trans to springfield to trans shop since none are local
    thanks
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    we dont have a store here that carries trannies, lol,.
    everything is in springfield and bloomington
    thanks
  7. hardcore71
    hardcore71 Registered Member
    Nov 21, 2002
    86
    Weare NH
    Sorry for the late reply. No reverse, 4th, and I bet it takes longer than usual to shift ou of first. You have a broken reverse sun shell. Very common problem in these trannies. The long time to shift out of first is because 2nd is gone too. You are shifting right from 1st to 3rd. The good news is a new shell is only about $65-$75. The bad news is that the tranny has to come out and be torn down to change it. With those miles it would be moronic to not do an overhaul or at least reclutch it at the same time.
