97 chevy 1500 Solid axle swap questions
Discussion in 'The Garage' started by pulser9, May 21, 2006.
  1. pulser9
    pulser9 Registered Member
    Mar 20, 2006
    65
    NJ
    Ok so my friend has a 97 1500. He wants to do a Solid Axle Swap. We want to do a dana 60 in the front and a 14 bolt rear. Im going to work on this project before i get a blazer and start my project. What we need to know is do they make a kit for a SAS for a 97 1500, if so what site has it? We want to run like 12 inches of lift and 38s. Also what trucks should i be looking to get the axles off of?
    Thanks,
    Kevin
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
  3. pulser9
    Mar 20, 2006
    65
    NJ
    Ok after we looked into he solid axle swap weve leaned against it. For one reason and one reason only, Money. I figure between the two axles, conversion kit, reagearing/rebuilding axles, springs, dual shocks would coast me around 5 grand then another 1400 for tires and weels. And alot of man hours. All this is to much. So we started looking into the whiplash 10 inch lift kit. Has anyone herd anything about this lift?
    thanks
    Kevin
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    your going to spend alot more money on an ifs lift and tire than you will an sas ive spent 100 bucks for far (not counting parts i had) on mine. So total for my front is:
    Complety rebuilt axle 1300 (dana 60)
    Mounts 80
    Shackles 100
    Springs 200
    Thats 1680. Not to bad. And if i went 10 bolt it coulda been alot cheaper
    Steering is like anothe 300. I included the arm in the price of the axle. Follow the link in my sig. It prolly took me 2-3 full days to do the front swap.
  5. 79k20350
    Nov 22, 2004
    7,757
    Ct
    That and 14 bolts are dirt cheap. Look in the ifs forums. me and 1 other guys have all done the swap for very little $$ i coulda done even cheaper but i used mounts i had previously bought.
  6. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    i had considered this for my 99,
    when I looked at lifting it with a quality kit a couple grand is an average price,
    but you still have stock tie rod ends, stock cvs, and now you have actually a weaker set up due to the increased leverage of a larger tire and the angles that have increased.
    then add the drive shafts, the 1400 tires and wheels and a fare amount of time, maybe 2 days.
    if you were to do it right and have a beefy ifs, its still getting near 5 grand.
    i wont do it simply because I work out of my truck, and I have blazers to take off road, not to mention this is my tow rig and resale is hurt by decreasing the amount of potintial buyers due to the lift/ appearance.
    the solid axel is the way to go, just aquire the parts and wait it out,\
    what does the conversion kit consist of?
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Honestly, anyone who buys a conversion kit should have their head examined.:rolleyes: Do even the smallest amount of research and find out just how cheap and easy it is to do. hell i even did mine completly differant than everybody elses. (using only 49" springs rather than 52- 56" and mine still was easy)
    You gotta think of how far ahead you come in strength, uniquiness, and quality. The straight axles is just so much better than the stock ifs for what we do, hell even daily driving, 10" of lift is not easy on an ifs system.
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    btw... my fender height (the outside lip of the fender) went from 32" stock (2wd height) to 50-51" all said and done:eek1: thats with 36's comparded to 30's too though. So the 36's stand 34", 34" - 30" = 4" / 2 = 2" so 51"- 2"= 49" 49"-32" = 17" of lift over stock using only a 6" lift spring for a 73-87 truck:eek1:
  9. pulser9
    Mar 20, 2006
    65
    NJ
    how much welding is involved in the conversion. Because i definetly wuldnt consider my welding top quality.
  10. 79k20350
    Nov 22, 2004
    7,757
    Ct
    ummm...none at all
  11. 79k20350
    Nov 22, 2004
    7,757
    Ct
    follow the link in my sig...youll have to pay 25 bucks to see the pic but it will save you $5000;) See most people dont see this site as saving them that much money but i know it saved me the cost of the kit so that more than worth the 25 bucks:rolleyes:
  12. pulser9
    Mar 20, 2006
    65
    NJ
    yea i didnt buy pay the 25 yet because i didnt have a chevy to work on yet but now were working on this one so i will.
  13. pulser9
    Mar 20, 2006
    65
    NJ
    Ok so what mounts and spring will i need to buy? And where can i buy them? Or am i going to have to fab them?
  14. 79k20350
    Nov 22, 2004
    7,757
    Ct
    READ THE BUILD UP THREADS for the 3rd time:rolleyes: THe info you need is in those threads.
  15. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
