97 GM deisel
Discussion in '1982-Present GM Diesel' started by bigtruck87, May 1, 2003.
  1. bigtruck87
    bigtruck87 Registered Member
    Mar 19, 2003
    33
    Treton, NJ
    I have....well my uncle has a 1997 surban with a 6.5 turbo deisel. well he will be driving and the truck will just die. sometimes it will restart and sometimes it wont. has a new filter and a new helper pump (the one on the rail.) still has the same problem. just wondering if there are any common problems for this concern with this motor??????
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I have zero experience with the later style (electronic) 6.5s. But I've heard the fuel pump is controlled by a fuel pressure switch w/no relay. The contacts in the switch suffer from too much amperage.
    Other than that it sounds like a PMD problem. They suffer from heat soak. Look for an aftermarket kit to remote mount it, although it still may have to replaced.
  3. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    The dealer should replace the injection pump under warranty. That is a classic symptom of bad electronic injection pump. (could be the electronics (as Dan said) on the pump but they just replace the whole pump AFAIK)
