97 S-10 problem
Discussion in '1983-2005 S-Series models' started by CK5, Jan 10, 2002.
  1. CK5
    May 19, 1999
    21,623
    701
    CO
    1997 Blazer, shift on the fly, It has the On-The-Fly 4-wheel drive, but when the button igets pushed it just flashes for a while and then quits. It won't go into 4-high or 4-low, any ideas?
    Steve
    Director of Global Expansion
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    are those vacuum, heat or electricly shifted? I'd check the fuses first.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  3. scotty1
    scotty1 1/2 ton status
    Jan 7, 2002
    166
    WV, Harpers Ferry
    Check the vacuum line to the CAD actuator, I think it will be under the battery in the front right fender on your truck.
    Git there fastest with the mostest!
    Nathan Bedford Forest&lt;P ID="edit"&gt;&lt;FONT class="small"&gt;&lt;EM&gt;Edited by scotty1 on 01/10/02 07:27 PM.&lt;/EM&gt;&lt;/FONT&gt;&lt;/P&gt;<P ID="edit"><FONT class="small">Edited by scotty1 on 01/10/02 07:28 PM.</FONT></P>
  4. Jamus
    Jamus Registered Member
    Jan 10, 2002
    29
    Morgantown, WV
    I have a push-button and it does that same thing only when shifting into low. You have it in neutral in order to shift and the light flashes. It sometimes requires you to shift into reverse and then into a forward gear. Does this sound like the same thing as on yours?
    94 Blazer, 4.3 cpi, 3" body lift, SFA with dana 30/Fors 9", 33's
  5. CK5
    May 19, 1999
    21,623
    701
    CO
    Thank's guys I will find out, this question is actually for someone else that is having a problem.
    Steve
  6. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    Vaccuum/electric control, I believe. I've got a '95 baby Blazer with the push-and-pray shift system as well. I hate it.
    I've had the same thing happen to me when I've tried to shift into 4Lo and the truck was either moving too fast in neutral, or stopped and things not lined up.
    1984 K5 Blazer 4x4 Silverado
    6.2L diesel, 700R4, 3.42 gears, 31x10.5" tires
