!976 Blazer Brake Lines
Discussion in 'The Garage' started by ike, Jan 25, 2006.
  1. ike
    ike Registered Member
    Jul 5, 2005
    96
    orange ca
    I just installed a 4' BDS lift on my 76 Blazer . Looks more like 6' I think they gave me the wrong kit..(looks good)
    . I need to buy some longer brake hoses..
    Any tips on what brand name hoses to buy and or where to buy the hoses .. My local small 4x4 shop is lookin to Hose me $200+ for three hoses.. I can have a custom set made up for around $175 in Long Beach... I found a set at a store on the web after surfing for less then a min. for $81 ...Then I thought hey I know who to ask ....here I am.....I'll post pictures of the truck when its back together..Thanks :wink1:
  2. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    I did a 4" bds and thought it looked tall myself. Mine came with little L brackets to drop the end of the hard line and that works fine. I've got great articulation and no line probs. If you go with new ones just do what your doing, surf that web. I have made my own s/s braided,teflon lined lines but DOT would not approve I'm sure.
  3. ike
    Jul 5, 2005
    96
    orange ca
    Brake hoses
    Yea my kit came with the L brackets to drop the metal lines but my hoses were not the best shape at the start of the kit install .. Then after having the diff. hang from them for months whille I put off finishing it up ,,, The hoses are done.. I needed to get the kit in... the truck is blocking my garage door and trapping my hotrods in !!
  4. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    Ahh.. I see, and trapped hotrods can get edgy, they need to be run hard on a daily basis. What do the normal oem replacement lines from raybestes or the like cost you? Thats how I would decide which lines to get. How big a $$ difference.
  5. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
  6. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    Alaska Rubber in Anchorage did mine for $50.00 (just the front two). But the flight up here would be cost-prohibitive.
  7. ike
    Jul 5, 2005
    96
    orange ca
    true but ..
    I would like to go to Alaska anyway ....
  8. AKbigsub
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    Come on up! If you drive up in June you could attend our anual meet and greet. The dates are June 9-11 at the Alaska State Fairgrounds in Palmer, just north of Anchorage. It's a fun time with seminars, trail runs, nice rigs, and good friends. It would be great to have more people from out of state attend! For more information, check out www.alaska4x4network.com and do a forum search in General Chit-Chat. Or go to http://www.akextreme4x4.com/meetngreet.htm
  9. ike
    Jul 5, 2005
    96
    orange ca
    brake hoses
    Ok .. I have the part numbers. Are these just for the fronts ??? What about the rear... I have a dana 44 so I'll have to ream the caliper out right... not tap it ..just ream it for the end of the hose fitting Im guessing... And whats the banjo is this somthing I will need to replace.... Thanks for any help I'm hoping I wont have to go have a custom set made... thanks
  10. ike
    Jul 5, 2005
    96
    orange ca
    hose man
    Ok Just got off the phone with a local shop... They charge $25 to $35 a hose ,, Custom made steel braided....;..
  11. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,015
    617
    Pueblo, CO
    late model 3500hd brake hoses...Cheap at your local bonyard. Ream the hole to 7/16" to fit the D44 caliper banjo bolt. Biggest problem was finding a bit big enough. The banjo fitting is brass and the drill bits cut it easy. Just use a couple smaller sized bits to work up to 7/16". Make sure to de-burr the edge with a small round file too...
    Did mine over a month ago and haven't leaked a drop. Truck stops just fine and I've rechecked it a few times just in case. Always dry...
  12. ike
    Jul 5, 2005
    96
    orange ca
    Your the cheapest
    OK just tak them off a truck at pick a part ....even cheaper !!! your the cheapest ... Sounds even better.... What about the rear line ??
