98 and below reliability ?'s
Discussion in '1992-Present Chevy & GMC models' started by altaboy8, Jul 8, 2002.
  1. altaboy8
    altaboy8 Registered Member
    Jul 8, 2002
    7
    98 and below reliability ?\'s
    i am a tacoma owner currently. i own an 01 tacoma 4x4 trd. it wasnt what i expected though. it will go where i want when i want but it had developed some ticky tack "non toyota" problems which have turned me off from the truck. so since this truck can pull around 19500 used id be looking at a 98 or 99 square body style 2wd lifted silverado ext. cab. how reliable honestly are the 5.7's im not going to be putting any money into gm's pocket by buying this truck because i will not buy from a dealer. so i would appreciate an honest and non biased opinion. thank you.
  2. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    Re: 98 and below reliability ?\'s
    The 350's as reliable of an engine as you will find in my opinion.
  3. altaboy8
    Jul 8, 2002
    7
    yeah my frieds uncle is a chev. mech he said if ur gonna go chevy get the 350 its our bread and butter. he said i should pull around 150k on the odo which is what i expect with my taco. does that sound about right?
  4. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    I have had several GM's in my life. In my opinion.........the 350 is a great engine. Definately get a Vortec engine. Very reliable. /forums/images/icons/smile.gif
  5. altaboy8
    Jul 8, 2002
    7
    would a 99 silverado 5.7 be a vortec? isnt vortec a counter balance to make the engine idle and run smoother? thanks.
  6. ChevyHuny
    ChevyHuny 1/2 ton status
    Aug 17, 2001
    2,279
    Washington State
    The '99s did not come with 5.7s They came with 4.3L V6 or 4.8L, 5.3L, or 6.0L V8s. The thing that makes those engines "vortec" engines is the heads and Air induction system. The bottom end is basically the same as other/older GM small blocks. Prior to 99 they had the 5.7 vortecs, but in 99 is when the newer vortec family was put out.
    Here is a link to better explain what improvements you have with a vortec engine.
    Vortec Engine Info
    Hope This Helps ....... /forums/images/icons/smile.gif
  7. altaboy8
    Jul 8, 2002
    7
    this is either a late model 98 they labeled a 99 or its a very early 99 labeled a 99 it is the square model though. thanks.
  8. ChevyHuny
    Aug 17, 2001
    2,279
    Washington State
    Either way, you would have yourself a vortec /forums/images/icons/grin.gif
  9. altaboy8
    Jul 8, 2002
    7
    lol so im a winner no matter what. im actually really familiar with ls1 camaros is the 5.7 in his 98 or 99 lol an ls1? i just got the trd taco cause i read dollar for dollar it is the best 4x4 out there. it might be but its not what i expected.
  10. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    In 99 you could still buy an older body style along side the newer Silverados. Actually there are a number of diffrences on the newer engins(4.8, 5.3, 6.0) as compared to the older ones. Deeper skirts, 6 bolt mains and numerus other things nothing is interchangeble.
  11. tjayandlisa
    tjayandlisa Registered Member
    Feb 14, 2002
    48
    Sacto CA
    the biggest advantage to a vortec motor is the roller cam...more longevity...less friction...
