'98 Astro w/bad cat. converter
Discussion in 'The Garage' started by Ressurection, Sep 27, 2005.
  1. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    I'm in an area that doesn't smog test. Would there be any reason not to just remove the bad cat and patch in a piece of pipe? Are there any tuning issues I'd have w/ the engine?
    Thanks!
    P.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you will have to get a o2 simulator or you will have a constant check engine light. This is because the computer uses a o2 sensor after the cat to make sure that it is working.
  3. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    simulator is just for offroad use. the fuel milage will go in the trash on the street. and if thay dont smog check then thay might do visuel only.
    how many miles? and what is the simtoms?
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the simulator should not affect the gas milage at all as long as it is only used on the rear sensor only. Only the front sensor affects the fuel delevery system the rear o2 sensor is used by the computer to make sure the cat is working by seeing a different reading then the sensor before the cat. It is only for emissions reasons.
  5. Ressurection
    May 9, 2000
    360
    The van has about 112,000 mi. I really want to hold or improve the gas milage and performance, which is why I'm considering eliminating it. The symptom is it rattles inside, and when I had an oil change the dealer told me that's the prob.
    Thx.
  6. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Just swap out the cat w/a bypass pipe. As stated on the other posts replace the O2 sensor w/a bypass also. The rear O2 sensor is so the OBDII computer can tell if the cat's are working. Is your check Eng. light on? If the Cat's are not working you should have a code stored in the OBD II computer.
    Dan..
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    02 sims on the rears wont hurt anything. I have a '99 1500 and i cut my cats out and it threw a code but hasent hurt anything I havent checked it but im pretty sure I picked up a few mpg (they get cloged after 100,000 miles or so) if you have a laptop and some software(or know someone who does) you can turn them off. Im going to turn mine off when I get my new tune
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    second set of O2 sensors are just there to monitor the Cats function. O2 simulators in place of them does nothing bad. Best is to just edit them out of the program though.
  9. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    Just poke all the catalyst out of the cat and just leave the empty box in place. Then no one will know that there is actualy no cat in there.
