98 yukon purchase
Discussion in '1992-Present Chevy & GMC models' started by joker89blazer, Jul 15, 2003.
  1. joker89blazer
    joker89blazer 1/2 ton status
    Nov 21, 2001
    130
    panama city florida zip 32409
    Looking at buying a yukon 100k miles
    have a few questions
    1] Should I be able to get 14-18 mpg on highway?
    2] What problem areas should I look for?
    3] Most I have seen have had push buttons for
    t-case. Is this as good as lever shift?
    4] There is a small knocking noise at front of
    motor,can not hear from inside cab.Could
    this be a bad idler or ?
    5] What axle ratios did these most often have?
    6] Is there any diferance other than appearance
    between gmc yukon and chevy tahoe?
    Thanks for looking
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Thanks for looking
    1.Yes
    2.Coolant leaks from manifold, front axle engaging and disengaging correctly.
    3.In my opinion NO, I prefer the TC lever
    4.Idler,Alt,AC comp, use a piece of hose to your ear to isolate the noise
    5.I would guess 3.73 or lower numerically (ie 3.42), but it might have 4.10 with a tow package
    6.No
  3. joker89blazer
    Nov 21, 2001
    130
    Thanks for the reply
