!983 K-5 Blazer Front Seats
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Huey, Sep 26, 2002.
  1. Huey
    Huey Registered Member
    Jul 4, 2001
    5
    Any suggestions for /forums/images/icons/confused.gif after market seats for an 1983 K-5 Blazer? How should I handle the "flip up" feature of the passenger side seat? I am looking for seats which accomodate full size people. A reclining feature would be nice.
  2. dyeager535
    26,980
    Well, I'd first do a search on here, because I think a few people have asked about this, and also figure out what you want/need the seats for.
    More comfort, just need seats, or need better support wheeling? Personally, I haven't heard or seen many complaints about the strength of the seat mounts themselves, (just the seats) so I'd just use stock mounts, and adapt different seats to them.
    I doubt the market is large enough that a company actually makes a bolt in replacement seat setup that will work with the tilt passenger seat.
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I put some seats from a '91 blazer in my '74. I retained the stock brackets. I used a 17"x17" 16 ga. steel plate and spot welded my stock brackets to the bottom of it. Then I drilled the 4 new bolts holes for the new seats. It took me all of about an hour to do everything including repainting the brackets. They look great and they look factory as well. They sit about 2" higher than stock, but I like that. I get more visibility. Also, they are the newer high back seats that recline and flip forward. I have less than $100 into them and the feel great! /forums/images/icons/smile.gif I can send you some pics if you're interested.
  4. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I thinking about looking for some Astro Van seats with arm rests. Someone from this site said they would bolt right on! /forums/images/icons/ooo.gif
  5. pops83k5
    pops83k5 Registered Member
    May 11, 2002
    30
    Basking Ridge, NJ
    I'd be interested in some pics. Does the passenger seat flip up or fold down?
  6. mattyblazer
    mattyblazer 1/2 ton status
    Sep 22, 2002
    202
    Long Island, NY
    I got '84 z28 seats to sit on the blazers seat mounts, with a little creative drilling and bolting... they look like they belong in there.
    Matt
  7. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    Beard makes seat mounts to fit there sits for seconds gens up to 86 with the flip up model, check then out at www.redart.com
  8. ryand7
    ryand7 Registered Member
    Apr 22, 2002
    11
    Mountains of NC
    I just put some seats in my 89K5. They are gray leather out of a 94 Suburban. Drivers side is power. Took about an hour had to drill two new holes in the suburban seat brackets and they bolted right in. Ran a hot wire to the wiring and it feels like I am in a caddy. Major improvement to the look and comfort of any K5.
  9. Grim-Reaper
    7,385
    Atlanta
    93ish Mitsubishi Mini Van middle row seats. Double arm rests, spin and recline. I can load a big Contico box through the passengerside. The seat tracks are 3ft long and have to be cut down. Getting into the back seat is a breeze now.
  10. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    It flips up on the stock brackets for the rear entry, but the seat back also flips forward or reclines if you want it to.
  11. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Grim reaper has a very good idea, but I would use the captain chairs from my custom chevy Van /forums/images/icons/smile.gif. Plenty of those in wreking yards if you want to do the same.
    IceMan
  12. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    weel i personally have new seats in my blazer.
    i have seats from a 2000 silverado. with a center console that flips up into a middle seat. when i removed the pass. seat with the brackets, the flip up feature came out too. when i put these in, the seats ran on tracks, the bolts on the front of the bolts were an EXACT match, then in the rear it was 6 inches off. so i took a metal plate, bolted the plate down, then bolted the seats to the plate, the plat is like 1/4 in steel and when i put the seats in it i raised them .5inches. and to get into the rear, the seat slides fwd, and folds up.
    i have pics at my webshots page:
    The pics are here @ my webshots page
  13. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I've got some gray cloth seats out of a '99 Tahoe. The passenger side slidees forward, and the drivers side is power
    Do a search, this has been covered a bunch of times
  14. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    I have some 2000 Astro van seats that I got for free out of a roll over from the J/Y. I saw them and wanted them and they told me if they cut the roof of then they would burn the seats. I told them I could get them out and told me if you can then they are free. I layed in the seats up side down and pushed on the roof with my legs. After a few the roof was all up and there was room to work. Hay, free is free....right!
    I tired to fit them in and it look like I need to make brackets for them. Here are a few pics of them
    Seats
  15. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    That is why I made a plate for my stock brackets and spot welded them to it. From the pics, it lookes like you can unbolt the stock Astro bracket from the seats, then all you have to do is drill 4 holes through the plate and bolt them onto you stock K5 brackets. You won't lose andy form, or function /forums/images/icons/cool.gif
  16. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    I was going to do that but the seat brackets are also the seat sliders so, I have to think of something else.
  17. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Ahh, I get it, you want to keep the sliders on the passenger side?? My drivers side still has the factory sliders. My passenger is a fixed position that flips forward for access to the back seat. That is why the new plate on the original sliders worked for me.
