$99 BlazenOffroad Rocksliders!!!!!!!!
Discussion in 'Vendor Forum' started by 81jimmyslt, Oct 9, 2006.
  1. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
  2. 81jimmyslt
    Jun 5, 2003
    1,643
  3. 81jimmyslt
    Jun 5, 2003
    1,643
    Thanks again everyone!
    Jesse
  4. chevyridinhigh79
    chevyridinhigh79 1/2 ton status
    Dec 1, 2006
    1,076
    Steel City, PA
    will these fit a pickup or just a blazer? what do the weld in sliders weld to? what do the bolt in sliders bolt to? can these also be used as a step?
  5. 81jimmyslt
    Jun 5, 2003
    1,643
    Here is a good thread, a customer did a full write up on the weld in rock sliders http://coloradok5.com/forums/showthread.php?t=165951
    Both setups work for blazers, only the weld in kits work for the trucks. We actually have new truck bolt on sliders in the works though.
    They bolt to the body core supports right underneath the rockers, there are 2 on a blazer.
    Check our website for more info www.blazenoffroad.com
    These ones could have been mounted higher but it give you flexibility. Check the website for step kits that can be added to the rock sliders!
    Jesse
    Oh and Welcome to CK5!!
  6. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Will the bolt on truck sliders be produced for longbeds? If so put me down for a set.
  7. 81jimmyslt
    Jun 5, 2003
    1,643
    What year is your truck!
  8. Cricket
    Nov 29, 2004
    8,224
    Colorado
    1977, you can view it in the Member gallery pictures.
  9. 81jimmyslt
    Jun 5, 2003
    1,643
    I'll have to get back to you with some measurements of the short bed brackets and we will see if they are the same.
  10. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Sounds good.
  11. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    Please post some pics of these pick up sliders whan you get some done. I'm interested and want to see where they mount. My concern is if thay are bolted to the cab and the box they might do some body damage when the frame twists.
  12. 81jimmyslt
    Jun 5, 2003
    1,643
    Thats definately a good point sope.
  13. JC_
    JC_ Registered Member
    Sep 21, 2006
    98
    Indiana
    How much weight could I put on them? I have an idea....
  14. 81jimmyslt
    Jun 5, 2003
    1,643
    Well you can use them as a high lift point.
  15. Cricket
    Nov 29, 2004
    8,224
    Colorado
    How hard would it be to make the longbed sliders a 2 piece set-up. One for the cab section that would mount to the supports and one for the box section that would mount to the frame. Obviously the saddle tank would have to go but most of us serious enough to use sliders would switch to a K5 tank and mount it further back under the bed.
    This way you'd still have the flex and the protection for situations like this, the flex here was enough to pop the tailgate and you can see the difference between cab and bed.
  16. 81jimmyslt
    Jun 5, 2003
    1,643
    Ya the saddle bag tanks are your biggest problem, and that is why we don't have a bolt in setup yet for trucks.
    Yes a two piece design could work.
  17. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Well if you decide to make those sliders I would drop the saddle bag in a heartbeat for a pair. It was already part of my build plan since I've gone TBI.
  18. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    Any plans to make some that also replace the rocker pannels?
    ignore that. see one of your customers used them for that.
  19. dbreid
    dbreid 1/2 ton status
    Dec 26, 2005
    379
    San Mateo CA
    Do you have the Bolt in ones for Suburbans?
  20. 81jimmyslt
    Jun 5, 2003
    1,643
    What year you looking for? Yes we can make some.
