99' burb questions about - t-case and axle swap
Discussion in '1936-Present Suburban' started by MilpitasK5, Feb 25, 2003.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    99\' burb questions about - t-case and axle swap
    What transfer case or cases was the 99' burb equipt with?
    It's a 1/2 ton and also needs a new rear end.
    Will a 14 bolt SF bolt up to this?
    TIA
  2. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Re: 99\' burb questions about - t-case and axle swap
    Yes, the 14-bolt SF from a pickup will bolt in. Look for a K1500 with F44 option or a K2500 with 6-lug wheels. Both have the same WMS and spring spacing. The C2500 6-lug is narrower. You either need to fab sway bar brackets or ditch the sway bar since the pickups don't use one.
    Oh yeah, this applies to the 88-99 style trucks.
    Since its a '99, its probably got the auto-trac t-case.
