99 powerstroke problem
Discussion in 'The Garage' started by clarkjw24, Dec 12, 2004.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Got a 99 7.3 powerstroke. Manual tranny. Its not running right. Has a skip and the fuel milage has dropped drastically. Where do I start on trouble shooting?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    what do you mean by a skip? not throwing any codes?
  3. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    A while back it show a water in fuel warning light but we drained and replaced the filter. Ever since then the skip/hesitation problem has gotten worse. No other warnings/service lights have come on.
  4. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    not a diesel expert but it sounds like a sticky injector from water intrusion...
  5. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Make sure you've got a good seal on the filter- Could be leaking air? Does this problem only occur on throttle or also at idle?
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    If you sucked up some water it will destroy the injector(s). Water doesn't lubricate, diesel plays a big role as a lubricant in the fuel system.
  7. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    Sounds like an injector you can not change it your self because you have to use a special tool to pull the injector. One thing that I have found very common on them is the wiring for the injectors runs throught the valve cover gasket and it burns up inside the connector. The injectors used 110 volts to fire the injector so be very careful when playing with the injector wiring. A Injector cost about $800-1000 a piece if you have to replace one take it to the dealer and that does not include any labor. Try changing the valve cover gasket first it is only about 20-30 a piece from Ford. If you had air getting in it would smooth out after a few seconds to a minute. If the filter did not seat fully you would have fuel getting all over the place. I have had a few that have come through the shop with bad injectors all of them have had to go to the dealership to have them replaced. Hope this helps some.
    bigred81
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    It takes a special tool to change a navistar injector? :screwy: That must be an international thing. ;) I have changed injectors in 60 series detroits without a problem and I hear a good mechanic can change the injectors in an ISB cummins in 20 minutes. :p: :grin:
