99 Yukon right rear blinker ??????????
Discussion in '1992-Present Chevy & GMC models' started by jesterdzs, Oct 10, 2006.
  1. jesterdzs
    jesterdzs Registered Member
    Jul 7, 2005
    Silverspring , Maryland
    just bought a 99 yukon ithought it just had a bad tail light bulb , replaced it 2 times but................. :mad: its still not working , any ideas as to what else i could check , wiring looks excelent no cuts or splices , but it does have a factory trailering harness .......... but it looks good to , all the other bulbs work , the front blinker works finr, the bulb does look dim when the lights are on but wont blink ,
    Please help :confused:
  2. sweetk30
    Nov 1, 2004
    horseheads , ny 14845
    if its the old c/k 88-up body the cirkit board is probly bad. thay have aftermarket now.
    if 99-up silverado body then ? havent played with them much yet.
  3. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    Truckee, CA
    Before you buy a new board, take apart the trailer wiring harness. Our burb always blew turn signal fuses. I unplugged the one we had on a 96 burb and it was full of water - probably 6 months after we had launched our boat! Clean it out if its gross....dry it out, and put it back together. Ours still had a problem, so i bought one of the Uhaul harnesses (with the status lights and everything, and you can get the nice cap/bracket setup if you want too) and it solved the problem.
