9c1 Police cars, anyone know where to get info?
Discussion in 'The Garage' started by sled_dog, Aug 4, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I've got a motor out of a 1989 Chevy Caprice 9C1. Its a 350, two bolt mains, with factory roller camshaft. Had an electronic QJet on top of the intake and thas all I know about it. I want to try and find out what camshaft it has. Someone told my buddy it is an L98 camshaft but we can't find any other sources to prove this. I'm builing a 383 stroker motor out of it and would hate to choke the damn thing with a simple stock camshaft. Though I am going to be choking it with an upgraded TBI.
  2. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I rebuilt a 91 cop car motor for my blazer. Stock short block, bored over, sportsman II heads, performer RPM intake, holley 750, corvette manifolds, and it pulls like a freight train. Stock cam. For moneys sake, I would keep the stock cam and get some 1.6 roller rockers. Small cam=Torque, Big cam=horsepower. Which do you want?
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    This time I read your WHOLE post. /forums/images/graemlins/whistling.gif
    I read a lot over at the Impala SS Forum (a lot of LT1 stuff, but do cover older B- body material)and I seem to recall reading that the TBI 9C1 engines had the L98 Cam. You might want to do a search over there to confirm or post up the question. /forums/images/graemlins/thumb.gif
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Everything i have read about the 9c1 engines said they have the L98 cam. The L98 cam is compatable with TBI But you need the chip for it. You can get one from GM. Not sure how it would work on a 383 tho
  6. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
  7. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Turbo City can probably burn a good chip for your computer. If the cam is in fact an L98, you should be able to just tell them that (along with the other motor info), and the chip should be good for what you're doing.
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'm not worried about getting a chip, I will probably have Turbo City burn mine. I know I will need one, with the 383, different valvetrain and head work. BUt I know I need to know exactly what the camshaft is to go with that.
  9. jarheadk5
    Mar 6, 2000
    4,389
    PA
    I'm thinkin' the only way to really "know" what you've got for a cam will be to actually measure it.
    OR, did GM by chance stamp/engrave/cast/forge/whatever some kind of identifier into their cams someplace? If they did, it might be worth the effort to pull the cam out and check (if it's not out already).
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    its out, but its with the block at the machinist, I will look when i get it back.
