A 85 K20 with 454 and air
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nikk, Mar 25, 2003.
  1. Nikk
    Nikk Registered Member
    Dec 16, 2002
    34
    Lacrosse, WI
    I'm thinking of installing a 454 thats in the garage to replace a 350 that runs good but has one weak cylider. I'm wondering if my AC compressor will bolt up on the same side (drivers). I already have a big block power steering pump bracket so that wont be a problem. Is there any thing else I should be aware of. Pics of a big block installed with AC (with the small compressor) in someones truck would be a big help! Thanks
  2. Nikk
    Dec 16, 2002
    34
    Lacrosse, WI
    TTT
  3. aahomerepair
    aahomerepair Registered Member
    Jan 31, 2003
    35
    Springfield,MO
    i can't help with the pic's of the small comp.but all the
    bb mount's are different that the sb,i have the long comp.on my 454 and i like them better and they are cheaper to replace 99.00 unlike 180-250 and if you don't have all
    the mount's yet the junk yard's are going to rape you
  4. Miller
    Miller Registered Member
    Mar 21, 2003
    56
    Mtn Home Idaho
    what do you mean its got one week cylinder, how much weaker, bet you did a compression check to come up with that conclusion.
    Id look to other places for a low compression reading if that was infact what your thinkn by a weak cylinder.
