a/c blower motor
Discussion in 'The Garage' started by chvymudin3388, Jun 29, 2006.
  1. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    my a/c only works on high any lower positiona nd it doesnt work. and its not the resistor.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I had the same problem yesterday. The switch was dirty. It looked clean enough, but a squirt of electrical cleaner later I am good to go.
  3. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    naw that wasnt my problem lol i found its my relay to my ac the little box that is right before the motor screwed to the side of the a/c box
  4. r3r3r
    r3r3r Newbie
    Nov 5, 2006
    Ca
    I had a similar problem on my 1991 (K5/1500 series) Blazer this morning. The fan would only run on low, and none of the switch settings seemed to be working. It worked fine last time I checked, but it doesn't get too hot here in Santa Cruz... Since we are preparing for a long trip (into the desert, etc.) I wanted to get the fan working again right away.
    So, I took everything apart (including the dash bezel to get to the fan switch in the heat/ac controls) and checked for worn and loose connections on all the electrical connectors. I checked the resistor, and even though it was rusty, all of the springs were intact.
    Then I cleaned all of the connections (relay/resistor/switch) and tested it again a few times. All 4 speeds working fine. I put it back together and I'm ready to roll. ;)
  5. blaznjon
    blaznjon 1/2 ton status
    Mar 6, 2004
    153
    Seaside CA.
    Go ahead and replace the relay.Cleaning the contacts is only a temporary fix.
