A/C blower relay
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wraenking, Jul 2, 2003.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    hey guys. my ac was only blowing out on high, so i got a new relay switch. i put the new one in, and now it is blowing the fuse when i turn on the air.
    any suggestions?
    thanks guys /forums/images/graemlins/thumb.gif
  2. cdh
    cdh Registered Member
    May 6, 2002
    69
    Gilbert, Arizona
    Check the switch on the dash. My switch had a short and started a small fire. Once the switch (and some wires) were replaced everything worked fine.
  3. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    it is only blowing the fuse when i put the a/c on high. i checked the ground, and its good. how can i check if its a power wire shorting? maybe i just bought a bad switch?
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    check hot wires for any ground in them at any time, soudn slike short somewhere, trace the harness on pass side underhood, make sure no insulation is broken or chewed through, and switch is definitely possible, try another one from another truck laying around, hopefully you know for sure that the blower motor is fine and not messed up burnt or shorted windings.
    should suspect components before wiring, rule of thumb usually
