A/C Clutch removal?? Any hints/tips?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dale_gribble, Oct 9, 2006.
  1. dale_gribble
    dale_gribble Registered Member
    Sep 20, 2006
    90
    Utah
    I ran a search, couldn't find anything. The bearing in the A/C clutch assembly is making a racket. Being the fact that the whole clutch assembly is $110 and a bearing is $10, I decided on the latter.
    Anyone swapped this bearing? Any help would be appreciated, regarding the clutch removal and bearing replacement. Thanks!
  2. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    special tools and there is specs as to free play and air gaps. i might not try this my self. but thats me.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Need to go down to auto parts store and buy a AC clutch puller/installer. Back out nut on the compressor shaft.Thread on the puller pull clutch/pully assembly and remove pully/clutch assembly. Take out the snap rings that hold the bearing in. Gently tap out the bearing. Reinstall. Dont tighten up the compressor shaft nut too much or the clutch faces will rub. There are measurements for the air gap between them. But i usually just get the faces close enough togeather so the clutch faces dont rub. Also allow a little extra gap for heat expantion.
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Gap is around 25 thou if I remember correctly. A business card thickness!
