A/C compressor question.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Derf00, Jun 3, 2001.
  1. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Friday during a massive rainstorm, the Jimmy threw a fan belt. That was an easy fix, but the belt hit the A/C electrical connection when it came off and wiped it out. It broke off one terminal and bent the second one flat against the compressor. Is this repairable or was this a very expensive A/C belt??
    Derf00
    http://www.derf00.coloradok5.com
    "Four wheel drive allows you to get stuck in a more inaccessible place."
  2. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    Try and solder the wires on. Don't know much about the assembly, but if you got metal showing on the broken pin, you may be able to solder to it.
    85 Burb and an 89 Blazer
    One just for fun, one simply for pleazer
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    A rebuilt ac compressor clutch goes for about 85 bucks!!!!! If you can't do a solder job try a junkyard for a core compressor and take the clutch off and replace the broken one.
    "My blazer may be slow, but it goes faster at higher speeds"
    Jim
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You might also try watching EBay - I got a new compressor for the wife's Cherokee for 12.00 off there.
    I'm so poor I can't even pay attention [​IMG]
  5. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    The two tangs that are bent and broken belong to the coil....which is hidden inside the clutch hub....autzone sells reman compressors for $60....cheaper than the price of a new clutch....it does require speacial tools to remove the outer hub and a puller to remove the clutch pulley....then a snap ring holds the coil to the front of the compressor...if you have the tools it can be done on the vehicle in about one hour...clutch gap 15K....if it is an OEM comp lookout for the nut attached to the compressor shaft...it will have to be removed first or you will destroy the snout of the compressor crank!
    Azblazer
    1979 K5 350 TBI
    1976 K5 Chalet
    If it ain't got arizona pinstriping.....you ain't wheelin the pee outa her!
