A/C compressor runs when heat is turned on
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dammit32, Sep 1, 2002.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    I work on trying to fill my A/C this summer...put two cans of stuff in it and the compressor would turn on for a few secs and shut off . I asked on the board here and the guys said it probably needed more or maybe the pressures were off or something...I was a lil flustered and had alot of other projects going and the A/C took last in line ...i thought it would be a quick fix....now that its colder here in Maine i turned on my heat this week and that compressor turns on and off like it was when i was trying to use the A/C.....
    I dont care if the A/C doesnt work this year but i dont wanna burn it out......HELP! /forums/images/icons/confused.gif
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Is it running in all the heater settings or just defrost? It is supposed to run in defrost to help get the moisture out of the cab. Your selector switch may be messed up if it runs all the time, my friend's was burnt inside and the compressor would run all the time. If you dont want it to kick in just unplug the wires that connect to the compressor.
  3. Txstruck
    Txstruck Registered Member
    May 25, 2002
    87
    Seagoville, Texas
    Most mormally do run when the heat is on but just to keep the windows from fogging
