A/C compressor wiring help
Discussion in 'The Garage' started by crumps, Jun 17, 2005.
  1. crumps
    crumps Newbie
    Mar 24, 2005
    Dallas, Tx
    Hello,
    1987 K-5 Blazer, my question is about the wiring at the A/C compressor.
    At the point where the wires enter the plastic wiring plug, there is a solid core piece of wire bridging the black wire to the green wire. This doesn't look right to me but I wanted to get advice before I rip that extra wire out. The previous owner had some work done and then complained of blowing fuses every time the compressor tried to engage so he just disconnected the plug.
    My wiring diagrams (Haynes manual) are not detailed enough for me to make a decision.
    Any help is appreciated, thanks.
    Craig
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    One green goes to one spade on clutch , one black comes from one clutch spade to ground . Get a new connector from a junkyard or another member .
  3. crumps
    crumps Newbie
    Mar 24, 2005
    Dallas, Tx
    Thanks,
    One spade with green wire, check.
    One spade with black wire, check.
    Wire bridging two spades together? Yes or no? Sounds crazy to do that with a ground wire...
    I'd post a pic but I don't have a digital camera...I still like film!
    Craig
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The single green comes from wiring harness to one spade .
    The black runs from the other spade to ground .
    Nothing bridged .
    the green CANNOT bridge the black , it would pop fuses , it needs to go through the clutch coil first .
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I think what he has on there is something like a diode or some other kind of electronic component, my old car i had, had this bridging the two wires, not sure what it was for, i just disconnented it.
  6. crumps
    crumps Newbie
    Mar 24, 2005
    Dallas, Tx
    Yes, it does look like it could be a diode. I'm not an EE so I'm not sure why it would be there.
  7. 4xcrazy
    Oct 31, 2003
    9,471
    5
    I just eliminated mine, worked fine, don't think it's actually a diode, but i believe it has something to do with limiting the current to the compressor, but as i also said, i eliminated mine, worked fine.
    Have fun,,,
  8. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    its a diode. its used for spike protection and feedback protection. thay are a 1 way electric valve.
