a/c compressor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by choper, Nov 9, 2001.
  1. choper
    choper Newbie
    Nov 9, 2001
    3
    hello everyone i'm new to this board and the problem i have is
    that i put headers on my 1986 blazer with the driver side
    a/c compessor. my ? is how do i mount it when the headers are in the way, any ideas would be appreciated
  2. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    What kind of headers, motor etc. This will make a difference. For instance my AC bolts right up with no interference with the headers. I have hooker comps on a BBC.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sounds like you have the wrong headers for your application. On some models there's a special bracket that you have to buy to get the a/c compressor reinstalled. But if there's a header tube physically in the way, then something isn't right. [​IMG]
  4. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I have headers and high rise valve covers.
    I had to get a longer A/C belt to allow the compressor to swing farther to the drivers side in order to clear the valve covers.
    Check and see if a longer A/C belt would help you at all.
    Good luck,
    Thomas.
    -- '84 1-Ton Blazer --
    When the goin' gets tough,
    the tough go 1-Ton [​IMG]
  5. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    You have to buy a special bracket. When I put my headders on the special bracket was on back order (I still haven't got it, I think they cancelled my order because it was on backorder for a month or something). I took off the stock rear bracket (the one that gets replaced by the special one) and used spacers and an original manifold bolt to mount the little triangular front bracket for the a/c and power steering pump. It's been holding for over a month with no problems yet, but I need to reorder the special one because compressor is starting to sag a little.
    77 Blazer, 350, NP203, K&N, 31-inch Cooper Discoverers
    <a target="_blank" href=http://community.webshots.com/user/jonathandwill>http://community.webshots.com/user/jonathandwill</a>
  6. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    I used a plasma cutter to cut out the old bracket on my 86.....
    Let me send you a picture of it. I then used an old bolt to secure it.
    Chris
    <a target="_blank" href=http://www.geocities.com/keywestk5/KeyWestK5.html>http://www.geocities.com/keywestk5/KeyWestK5.html</a>
    So I says to him, I said, "get your own monkey."
    1986 K5, 350 GM Crate, 700R4, NP208
  7. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    You don't need your AC anyway. so just send it to me lol
    And please take some time and fill out your profile.
    Eric
    <a target="_blank" href=http://cethern.tripod.com/erics-home-page-and-other-stuff/>http://cethern.tripod.com/erics-home-page-and-other-stuff/</a>
    AMSOIL Dealer # 529948
    Cethern@interfold.com
  8. 1986Blazer
    Jun 13, 2001
    511
    I just posted pictures on my website of my Modified AC Bracket link. There two link at the top of my page for this bracket. Let me know if you have any questions.
    Chris
  9. 1986Blazer
    Jun 13, 2001
    511
    The bolt at the lower right corner of the bracket is an original exhaust manifold bolt. It is secured in the head using the last bolt hole at the far end of the head nearest the AC compressor. It goes through the last hole in the headder. Between the headder and the bracket is a steel bushing so the bracket will not compress inward too far. This setup worked great. Again, let me know if you have questions.
    1986 K5, 350 GM Crate, 700R4, NP208&lt;P ID="edit"&gt;&lt;FONT class="small"&gt;&lt;EM&gt;Edited by 1986Blazer on 11/09/01 08:47 PM.&lt;/EM&gt;&lt;/FONT&gt;&lt;/P&gt;<P ID="edit"><FONT class="small">Edited by 1986Blazer on 11/09/01 08:49 PM.</FONT></P>
  10. Jonathan
    Apr 14, 2001
    293
    Jegs sells the special bracket for like $15-$20 depending on brand. UPS actually delivered mine within about 15 minutes of my first post and it looks like it should bolt right in between the headder tubes and the headder bolts where the original one can't fit.
  11. 85Jimmy
    85Jimmy Registered Member
    Oct 30, 2001
    97
    Great Falls, Montana
    i did mine the same as yours it works good with flowtech headers too.
