A/C & defrost
Discussion in 'The Garage' started by fatboy, May 14, 2004.
  1. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    why does the ac pump activate when you turn on the defrost? The problem with that is I have a flexilite electric fan with the ac reley. So when the pump turns on so do the fans and slows the warm up? Anyone have a solution for me?
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    The AC comes on because it helps pull the moisture out of the air, wich causes the windows to fog up. I think the easiest way would be to put a switch on the fan so you can manually turn it off when it's not needed during the winter.
  3. johnc
    johnc Registered Member
    May 6, 2004
    68
    O.C., CA.
    Can't you wire it to the temp gauge some how so it will be automatic????? /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    run a toggle switch so you can manually turn off the fans /forums/images/graemlins/thumb.gif
  5. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I thought it was so the A/C got cycled during the winter time. /forums/images/graemlins/dunno.gif I can't see how it would help make the air dryer on my later model rig because the evap and heater core are seperated. IIRC. /forums/images/graemlins/thinking.gif /forums/images/graemlins/dunno.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The air blows across the a/c coil, which is cool, causing moisture in the air to condense on it. Then the air blows across the heater coil, heating it up. Running the a/c makes the defroster work a LOT better than without it.
    Electric fans need to be wired to come on with the a/c so that the pressure in the system doesn't get out of whack. Running the a/c with no airflow across the condensor is not a good thing to do.
  7. fatboy
    Jul 1, 2003
    290
    Tennesse
    OH! thanks maybe I wont do that then? So I am back where I started lmao /forums/images/graemlins/histerical.gif /forums/images/graemlins/thinking.gif
  8. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
    i agree on not overriding the fans on the radiator/condenser. heat and pressure gets WAY out of whack doing it. think about it, mechanical fans work fine and they are on....
