A/C drain hose??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, Jun 12, 2001.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I was wondering where the a/c drain hose is located. I think the moisture on my passenger side floorboard is from a/c condenstation. Does anybody know where to find this drain hose?
  2. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Could be the heater core.
  3. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    well, I ran my a/c on max, low and condensate started to form on the duct work, so i'm pretty postive its my a/c
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You have to open the evaporator housing to get to the tube. If your not getting too much water on the floor, I'd get some Permagum or RTV, and seal the seam where the evaporator housing meets the firewall.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.coloradok5.com>http://pugsley.coloradok5.com</A>
  5. Grim-Reaper
    7,385
    Atlanta
    Pugsly has it right. The A/C part is under the hood. I think the drain is just a weep hole formed into the housing. If it were plugged it could back flow in the area around the heater core but that's pretty rare and the water would have to be a couple inches deep. Run the A/C and see if you see it dripping behind the passenger side front tire. If it's driping it's not plugged. You sure it isn't antifreeze? Thats what does leak into the truck.
    Some other things to check would be leaks around the windsheild and rust through around the cowel.
    It's not my damn planet monkey boy!
    Grim-Reaper
