A/C fan not blowing hard enough?
Discussion in 'The Garage' started by stallion85, Jul 16, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    The fan in the K5 does not blow the air out hard enough, is there a different fan that can be installed ie. from another type of vehicle that will work better? I checked all the ducts and the are in place but aren't sealed very well. I probably am losing some pressure form that. Any tips on what some of you huys have done would be appreciated.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I split open the housing in the engine compartment , cleaned the evaporator coils , lots , and I mean lots of dirt came out . This improved my airflow through the evaporator tenfold . Made all the difference in the world . My big greenhouse of a truck feels good with the A/C on . Be careful when you do it . You can brush it and vacuum/compressed air it . Or you can buy a spray on cleaner that will evaporate at any A/C or appliance parts store . /forums/images/graemlins/k5.gif
  3. dyeager535
    26,982
    191
    AC fans are the most "powerful" out there.
    There might be different fan motor part numbers out there, but if anything, on the AC/HD fan setups, its most likely the difference in where the cooling vent hole is drilled.
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    That is basically all you can do without changing anything. I put a brand new evap in mine and I got a considerable amount of airflow increase after that.
  5. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Where and how do I go about doing that? You are referring to the black box below the heater coil hose?
  6. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    If you have a non A/C vehicle the fan does not perform very well. Purchase a new fan motor for an A/C equiped vehicle they work much better.
    /forums/images/graemlins/peace.gif
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I have a/c /forums/images/graemlins/grin.gif It's funny how many people assume my truck doesn't /forums/images/graemlins/smirk.gif They don't appreciate older trucks like we do /forums/images/graemlins/ignore.gif
