A/C fan won't work
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LA Bogger, Aug 13, 2002.
  1. LA Bogger
    LA Bogger 1/2 ton status
    May 19, 2000
    192
    Robins AFB, Georgia, USA
    A/C fan won\'t work
    I can feel the cold air in the vents but the fan just stopped haven't check the fuse yet. Is there any thing else I should be looking for. I hate electrics...
    Eat More Mud!!!
    AIRBORNE!!!
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Re: A/C fan won\'t work
    The fan motor itself. They always go bad.
  3. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    Turn you AC on full and get under the hood and gently wack the fan motor with a small hammer. If will likely start.....the brushes get old and stuck after many years.....just replace it, about $25 from the auto store.
  4. cdh
    cdh Registered Member
    May 6, 2002
    69
    Gilbert, Arizona
    Check the fan switch. The switch might be burned up.
  5. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Does it work at any speed? If it does it could be either the hi blower relay or the resistor pack.
  6. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Also check the ground wire...it is usually found on one of the mounting bolts for the fan.Although it may look good, unbolt it and clean it good.
