A/C & headers, anybody done this?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mlb79, Apr 22, 2002.
  1. mlb79
    mlb79 Registered Member
    May 24, 2001
    40
    evansville, IN
    I just installed a set of flowtech afterburner headers on an 81 3/4 ton 4x4. What a pain, and the instructions say use original factory bracket for the A/C, this in impossible without cutting the factory bracket as far as I can tell.
    Has anyone done this on a truck with the short A/C compressor. Pictures would be great. These things were the worst set of headers I have ever installed and I've done a few. Anybody with headers and A/C please help!!!
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Don't have any pics, but my 85 had Hedmans on it and there was no trouble with the A/C at all.
  3. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    Check out the bottom of my web page. There is a link to some pics of the mods I made to my A/C bracket with my Hedman Headers. Let me know if you have any questions. I used a plasma cutter to make the initial cuts then I used a grinder to smooth it all out.
  4. mlb79
    May 24, 2001
    40
    evansville, IN
    Thats what I thought! I had the bracket laid out so I could take it to work and torch it. I wanted somebody to verify what I thought before I butchered the bracket. Thanks for the replies!! The picture was perfect, exactly what I needed. Thanks again.
  5. stickshooter
    stickshooter Registered Member
    Oct 26, 2001
    23
    I'm putting mine on this afternoon, Dynomax headers. I know that these as well as Headman sell an additional part if you have A/C. I just put in a new longblock so everything is off my engine right now and should be relatively easy. I put the right side on last night and it just slipped in. I'll try to update you on my bracket situation tonight.
  6. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i got the bracket too...can't really see what it would hook to on my a/c??? i just cut my existing bracket like everybody else and it worked great! im sending back the dynomax bracket and getting my money back.
  7. mlb79
    May 24, 2001
    40
    evansville, IN
    The brackets I've seen that summit or Holley has appear to be for the long style compressors. I can see how that would work but I haven't seen anything for the short compressors. Cutting the factory bracket seems to be the best solution.
  8. RiceDaddy
    RiceDaddy Registered Member
    Feb 3, 2002
    79
    Tejas
    I just received a set of Dynomax headers yesterday. I have the long-style AC compressor, so I think I need the pre-fabbed bracket. Anyone have experience with header install with the bigger compressor?
