A/C - heater diverter door clip
Discussion in 'The Garage' started by BulldogK5, Mar 10, 2007.
  1. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    I am trying to get the A/C and heater working correctly in the crew cab. The white plastic connector on the main switch door is broken. I have tried to use one I made from wood and looked for other options. In the searches I found it is an approximate $1.50 part but nobody knows what I am trying to get. Even when I show them the part. Haven't tried a dealer yet but when I went to get the bolts with clips to hold the core box on I was told they were discontinued. I found a bolt so all I need is a solution to fix this stupid plastic piece. Help please.
  2. BulldogK5
    Sep 19, 2002
    4,158
    Brandon, MS
    Buehler? Buehler?
    Anyone? Anyone?
    Surely (and yes I will stop calling you Shirley) someone else has run into this problem besides Spickler and a banned former member.
    Please!
  3. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    I got one from the dealer a couple years ago.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Geez, I have half a dozen of them somewhere in the garage, courtesy of my local GM contact. If I get a chance to scour the workbench for them, you're welcome to one for free. PM me and remind me, as I'll be helping a fellow CK5er build his fence for most of the day tomorrow. :thumb:
  5. onebig76k5
    onebig76k5 Registered Member
    Oct 28, 2006
    35
    Huntsville, al
  6. Alumbaugh
    Alumbaugh Registered Member
    Dec 24, 2004
    32
    Spring Creek, NV
    Bought one from the dealership last year (O.K - maybe it was NAPA). Parts guy new exactly what I was talking about.
  7. BulldogK5
    Sep 19, 2002
    4,158
    Brandon, MS
    Thanks guys. I did try the NAPA and they looked at me like they were retarded (not to insult the mentally handicapped). I came up with a sort of solution but I have not done it yet due to possible clearance issue. Will check and see.
    Paul, I am going to PM you with a pic also. Thanks.
  8. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Were you able to fix the a/c yet? Just curious what it was.
  9. BulldogK5
    Sep 19, 2002
    4,158
    Brandon, MS
    Not yet. I haven't looked into it much as far as the A/C itself. Since I had the heater core out I removed all the ducts and vents and cleaned them all. Boy you sure let the dirt get in there real good.:rolleyes: It wasn't as bad as I thought it would be with the way you described the doors and the dust falling out but it is all ovver the firewall and in every nook and cranny. That is the reason a 45 min. to 2 hr. project has taken about 6 weeks to complete. I figured I only wanted to remove everything once.
