A/C heater wiring queston
Discussion in 'The Garage' started by clarkjw24, Dec 3, 2004.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    There is a solid lonesome brown wire, under the dash in the A/C heater harness. It has a female plug. Where does this plug go? The whole switch seems not to be getting power. I've checked the relay and I only have power on the big red wire. I'm thinking I need it on about 3 of those wires. The fan motor is good and the resister seems ok. Why can't I get any blower controls?
    Also I can't get my fuel tank to register.
    These are the only issues I have after installing a complete harness, A/C,gas tank, motor and steering column in my K5. Help me please. This will have to be my DD since I've sold my S10 and my other K5 seems to have lost its doors and top.
  2. dyeager535
    26,979
    IIRC, thats the 12V feed wire to the switch, which comes off the fuse panel.
    Been awhile since I last dealt with mine, but I do recall that there is a connector between the switch and the fuse panel.
  3. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Is that brown wire have a tendency to get grounded out or even melted ? My HVAC controls will instantlyblow a fuse. Are there other wiring harness that plug into the back of the controls in the dash?
    Blake
  4. dyeager535
    26,979
    AC is a bit different as I recall, but in my non-ac setup, I can't see it being easy to have problems.
    One brown wire from the fuse panel, then the wires to the heater blower from the fan switch.
  5. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Brown wire to fuse box fixed it. Now hows about the fuel gauge?
  6. dyeager535
    26,979
    Start a new thread, but post up what it does.
    From my experience, incorrect reading, but still reads relative to fuel level, is the sender rheostat, if the gauge bounces as fuel sloshes, the gauge is shot.
