A/C is giving me a headache
Discussion in 'The Garage' started by jimmyjack, Jun 20, 2004.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    OK awhikle back I posted about my ac working except on HI speed. Low and medium are fine, but this Arizona and they're not worth a crap. I replaced the switch, the relay, AND the fan. HI speed still doesn't work! Am I missing something here? My test light is less than desirable so it isn't helping me much. By the way, I ran a jumper from the battery straight to the fan (for hi speed). It runs great.
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Did you replace the "high speed" relay, or the other relay?
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Musta just been the "other" relay, Where is the HI speed relay located?
  4. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    OK, I put two and dos together, got 5.........I figured I'd attack a bunch of wires thsat were all taped together. Traced a blue wire from the relay to a connector on the plastic box everything is attached to. I pulled the thing out and it was a "buss" setup with springs coiled at the end connecting the buss together. I worked everything all back and forth and sprayed some lectrakleen on it and now the hi speed is kickin ass!!! At least I know where it is now. Thanks for the help!
  5. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Good to see you figured it out! It's been bugging you for a while now. /forums/images/graemlins/waytogo.gif
  6. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    It you want a serious A/C for the hot Arizona desert sun, then try one of these on for size. These are built for medium size trucks, and cost about $1200. They mount on to the roof of your vehicle like a motor home A/C does. I live in Las Vegas, and want to get one for my 1-Ton 4X4 Crew Cab one day; although, I will have to cut a hole in my roof to install this self contained A/C unit. it will be worth it on a hot 123 degree summer day here in Las Vegas. Because this unit is self-contained, and comes with its own compressor, condenser, and receiver dryer, it will take off the load and heat A/C creates on an engine.
  7. 4xcrazy
    Oct 31, 2003
    9,471
    5
    I thought about installing one of those on the rear portion of the Burb, as i did the 134 conversion, and it doesn't work worth a crap, i wish i had never done the conversion.
  8. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Thats sweeeeet! I didn't pay that much for my blazer 11 yrs ago tho! A little out of my money scale. /forums/images/graemlins/frown.gif
