A/C not blowing enough
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by TONYP, Sep 9, 2002.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    just got my a/c going, it blows cold air (checked at 45') but not even hard enough to cool the truck, going to replace the fan to see if a newer one will move more air, then try to clean the condenser off to. Has anyone messed with this and what did you do to help the a/c out?
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    1. Check for the usual rat's nest in the heater boxes that blocks off the air flow.
    2. Make sure that your fan is operating on all speeds. It is common to find a bad switch that will not allow the fan to run at the fastest speed. The fans in these trucks really blow if all is as it should be.
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    check for cracks in the vent tubes. they tend to break at the connections to the vents.
    ARQ.
  4. TONYP
    Aug 13, 2002
    2,116
    so cal
    I have all new hoses to the vents and do get good flow, my fan only has 2 speeds, but have the new motor to go in this week. the speeds I have I think are the low and the high.
  5. Tonka
    Tonka Registered Member
    Jan 28, 2001
    30
    Fort Worth TX
    Chances are its the high speed you don't have. The high speed circuit runs through a relay that sometimes goes bad. I can't say for sure if this is your problem but it has happenened to me. I actually did a quick fix for awhile and routed the fan high speed through a relay for my off road lights. Gotta use a relay though, that fan sucks some power.
