A/C not cooling, need help
Discussion in 'The Garage' started by jkwoffroad, Apr 19, 2006.
  1. jkwoffroad
    jkwoffroad Registered Member
    Sep 29, 2005
    33
    New Albany, Mississippi
    My A/C on my 97 Chevy Z71 is not cooling like it used to. I've checked the refrigerant pressures and they seem to be good. I blows kinda cold air but not as cold as I hink it should. We had a 90 degree day the other day and I had to run on hi to stay cool. I replaced the compressor a few years ago and flushed the system them. I also remember replacing a small screen filter where the line entered the condenser coil - wondered if maybe this is stopped up - if I didn't get the system completly flushed??? I also wondered if maybe the evaporator coil could be dirty, acting like insulation on the fins keeping it from cooling??? Just trying to get some advice before it gets really hot.
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Does your compressor cycle on/off at a normal rate or faster than usual?
  3. jkwoffroad
    Sep 29, 2005
    33
    It stays on at what I would consider is notmal. It doesn't go on and off every few seconds like I think it would if it was low.
  4. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    Check the dryer or other part of A/C system I cant actually remember what its called.
    My dads truck is a 97 as well and the A/C is really crappy right now, even after a new compressor was put in. I was told by a mechanic to have dryer cleaned out or put new one.
  5. Wishbone
    Wishbone 1/2 ton status
    Mar 6, 2006
    239
    Oklahoma
    Put some dye in it and check for leaks.
