A/C not working
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Jan 10, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    It was warm yesterday, i and tried to turn my A/C on and it doesn't work. I just got it fixed about a year and a half ago. The heater sill works, i think, I'll check later. Where should i check connectons for it? i wish we could do a/c work legally...
    90K5
  2. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    If you have not used it in a while your freon more than likely leaked out. You should run your compressor at least once or twice a month to keep seals lubed. You also could have had a small leak. It is not illeagl to work on your a/c. You need to be certified to buy freon. i have the non automotive license. Also you can't evacuate freon into the atmosphere.
  3. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Check connections at compressor also connections on the evaporator box, this could be it. More than likly you are low on refridgerent. This happened to my k-10 after sitting for a few months.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There's a low pressure cutoff switch plumbed into the coolant lines. It prevents the compressor from kicking on when the freon pressure is too low, so the compressor doesn't destroy itself. If you have a slow leak, then the pressure may have dropped below the threshold.
  5. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    Check your electrical connections FIRST! Might save you some hassle!
  6. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    if you want to check to see if you have any leaks in your system and dont want to waste any r-12 you can use r-22 which is alot cheaper and wont hurt the compressor. when you are finished just realese the r-22 (dont tell any enviromentalists and it will be ok) and have it refiled with the r-12. if your rig is more than 6 years old its very likely that your seals are just worn out and you should be able to replace them yourself.
