A/C Problem...need help ASAP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nate87k5, May 27, 2000.
  1. Nate87k5
    Nate87k5 Registered Member
    77
    Phoenix, AZ
    87k5. When I turn on my A/C on Max and high the clutch will engage with the compressor but only for about 3 seconds and then disengage then engage again then disengage over and over. Need some help quick being that its going to be over 100 this weekend and I will have the kids in the Truck. Thanks for any help
  2. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    your low on r12 you need it topped off.You can by pass the switch (its on the dryer left side)but thats only a temp situation after a while it'll burn the pump. Does it cool well ?If it does cool it it only needs a .5lb maybeshould cost about 50$ but watch where you take it some locations will test it than tell you it needs parts after its drained completely than they wont refill it,so watch out.
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I can relate to your problem. I live in Tucson and its sposed to be 109 at least, look into a r134 conversion. Its fairly reasonable and it doesnt take a whole lot of effort.
  4. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    Try checking if there is a high pressure switch. This should be after the compressor. I doubt if this would cause it but check it anyway (just disconnect it). I also had this problem before but it ended up being the compressor being bad suction pressure of the compressor was too high......
    Blood, sweat, tears, and lots of money is what keeps my K5 alive.
  5. kim tate
    kim tate 1/2 ton status
    134
    New Orleans
    Coopertwpk is probably right, although I had this same symptom last summer and it turned out to be a bad pressure control switch. It's located on top of your accumulator. You can replace it without loosing any r12 because there's a schraeder valve under it. Most auto stores stock the switch - I think it was less than $15. Good luck.
