A/C question UPDATE 6-23
Discussion in '1992-Present Chevy & GMC models' started by MTBLAZER89, Mar 25, 2006.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    In my wifes 99 Tahoe the A/C doesn't blow cold. The rear air works fine, but up front doesn't. How do you recharge the system? Is this a dealer thing, or can I do it myself. How are the two systems separated? Why does one work, but not the other?
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    you have other problems. the freon is all one set with one pump. if the back is blowing cold then there is a door or plug in the front system.
  3. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Yeah, like sweetk30 said, both the front and rear use one compressor, so if it was low on refrigerant both systems would blow warm. Check to see if the blend door is moving all the way to cold, otherwise there is probobly a flow problem through the front system only.
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Damn that is not what I wanted to hear:mad: Oh well I'll check out the blend door.
  5. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    Actually that is what you WOULD want to hear :) replacing Compressor or other A/C parts in the engine bay is expensive and harder.
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    OK I read on fullsizechevy :rolleyes: (I know I know) there are 2 evaporators so that could be a problem. How do you check individual A/C components? Upon closer checks the front air gets cooler, but not as cold as the rear. How can I check the blending doors?
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Have you checked the pressures? I've read somewhere that the front system uses an orifice tube to create the pressure differential while the rear system uses an expansion valve. Perhaps one works better with low system pressure than the other? If so, then adding a bit more refrigerant could fix it. :)
  8. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    No I haven't checked the pressures. Where and how do I do that?
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    You need the proper gauges. Paid about $50 for mine, on sale at Harbor Freight. You really need to know what you're doing though when you add refrigerant. If you open the wrong valve on a hot day, you can feed 300+ PSI back into the can. NOT a good thing!
  10. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    my guess is one of the temperature actuators. or more than one. only way to tell is to find them and make sure they are moving when commaned to full hot or to full cold.
    or the orifice tube is plugged in the front system. if thats the case, the rear will plug soon and probably needs a compressor. and when the rear plugs will need an expansion valve.
    never really seen them leak. except from the compressor.
  11. HOSS874X4
    HOSS874X4 1/2 ton status
    Apr 17, 2005
    118
    DALLAS TEXAS
    ac control head is bad
  12. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Well I pulled the bottom cover of the a/c heater box under the dash. The evaporator I think thats what it is. Looks like a heater core, but cold LOL any way the lines to it and the evaporator itself are very cold. I can't see up in there to tell how the air blows across it. Does the fan ALWAYS blow through the evaporator? It appears to, but I don't know. If the evaporator is getting cold, but the air isn't coming out cold ????? Whats the deal here? The flapper door between the heater core and ac duct seems to work properly closed when on cold, and open on warm. The vent selector doors also appear to be working correctly. Has anybody actually taken this stuff apart that can help me?
    Help its getting hot:crazy:
  13. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    The evap core should only be cold when the a/c is on, and air always blows across it. If its getting cold, it would have to be an actuator. They aren't the most reliable things in the world (the actuators). I really can't remember which ones (should be two if its dual zone a/c). But you should be able to watch them move or not move when you change the setting from cold to hot.
  14. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Yeah the flapper door in between the heater core and evaporator is working correctly. Could the evap fins be plugged or something? The evap only gets cold when AC is on. Seems like a ****ty system to me with the heater core directly underneath the duct that carries A/C. That ****er gets hot:eek1: Maybe just low on 134 and the heater core is overriding the cool air, but the rear air isn't affected so it feels colder?? I dunno. What can be wrong withthe evaporator? Whats this stuff cost to have looked at?
  15. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Depends on the shop, at far as how much. Could be a couple pounds low and the rear just happens to be getting all of the flow. Should hold somewhere around 4 lbs of r134. So I would estimate 1.4 hours to evac and recharge and add ac dye. so at $80 bucks an hour, thats $112 bucks labor 7-10 bucks for the dye, and $20-30 a pound for r134. Maybe $200 if thats all it is.
  16. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Are you sure your heater control valve, under the hood, for water flow, is completely shutting,,,,i had this problem and i usually just bypass it every summer.
    If this is letting hot water through, even when you have the ac on, the heat will override the AC very badly.
  17. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    so the heater core is not supposed to get smoking hot when the A/C is on?? That could very well be the problem:mad:
  18. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    As far as I know, there is no such valve. Hot coolant always runs through the heater core. And always through the rear heater core as well.
  19. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    My truck never had one either , but the newer ones do , even the later R/V trucks from what I have heard from some friends with later model rigs .
  20. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    well that valve sounds better than cracking the A/C system open for parts replacement. Easier too.
