A/C removal question *PIC*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by B_to_C, Nov 19, 2004.
  1. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    My A/c copmressor blew up and I'm not going to fix it, so all this A/c stuff is just taking up space in my engine compartment. But is any of this stuff important?
    I can take all of the lines marked with YELLOW off with no consequences right? And how about that thing circled in RED? And that box circled in green...isn't that the heater blower motor in there? and if it is can I just disconnect the A/C stuff at the BLUE X?
    I plan on removing the A/C compressor and putting a York in its place for some on board air action sometime in the future.
    Also do you think anybody would want this stuff or should i just throw it away?
    /forums/images/graemlins/ears.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Be prepared to not have heat if you remove it all. The blower motor is one the passenger side right near the fender. You can remove all that stuff from the firewall and engine bay but you are going to loose your heater setup. I have a fix for this but it is still in the trial phases. I have made a prototype heater box to delete the AC stuff and keep the heater.
    FortCollinsRam has a prototype of my heater box in his possesion and should be installing it soon. I will know more when he gets it installed and when I get it installed on my truck.
    Yes you can delete it all including the AC compressor and also the condensor in front of the radiator. If you AC system is charged you will want to have it discharged by a shop. If it isn't charged then just remove everything.
    Harley
  3. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    The thing encircled by red is your accumulator dryer. It basically filters and dries the freeon in the system as it goes from a gas to a liquid and back again. You can remove it along with the lines without any problems. If it was me I would remove the lines, pump, condensor, and leave the blower housing alone.
  4. B_to_C
    Jan 15, 2003
    1,861
    Ok so it looks like I'm leaving my heater box alone. I guess I'll just take everything out and disconnect the A/C stuff at the blue X. Also, is there any danger if my system is still charged and I start to unscrew stuff?
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I imagine freon is harmful to people, and I know if it harmful to the planet. I don't know how dangerous it actually is to people but I know it is not good for you.
    Harley
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It is always reccomended to recover properly . However if accidentally released in a well ventilated area , it wouldn't harm you I don't think . I have been learning to to install compressors from a customer of mine ( we did my spare beer box , and Tj's spare beer box ) , and he said he has seen many people poke their old fridges by accident and no one he can think of ever got sick . /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  7. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    you can remove the stuff no prob yeah you *should* RECOVER IT BUT WHO REALLY CARES THERES NOT THAT MUCH IN THERE
    just so you know if you BURN the feon it will convert to mustered gas witch as most knoe will kill you.
    Ps im drinking excuse typos /forums/images/graemlins/screwy.gif
  8. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    if you were to accidently release the freon, just don't get any on you, it will cause frostbite
  9. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    You could remove it all, cover the holes in the firewall, remove the inside heat/ac box, then goto a junkyard and get a heat only inside box and then blower box that goes in the engine comparment (much much smaller than the AC version), and cut the holes for it. The firewall holes for AC versus non-ac trucks are very different. Oh, while your at the junkyard, get the control panel that goes into the dash, the AC one is all nasty vacuum operated, the heat only one is good ole' cables,you won't be able to hook the ac controller to a non-ac heatbox.
  10. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    I think the drinking has affected the mustard gas theory too. Freon is part of the Halon family, so when you use a Halon extinguisher on a fire does that also turn into mustard gas? /forums/images/graemlins/thinking.gif
  11. dave_90_blazer
    Jan 1, 2004
    688
