A/C switch problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kihlj, Jul 8, 2002.
  1. kihlj
    kihlj Registered Member
    Oct 16, 2001
    38
    Dallas, TX
    I just converted my A/C over to the 134a system and it is blowing cold once again. However, I have noticed that the vents down by the floor (in the center) are blowing no matter which setting I have on the a/c set to. I would think the only time that the bottom should blow is when I have it set to Bi-Level or heater. I have an '89 K5. Is this normal or is something wrong here?
    Thanks in advance for your help.
    Jason
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    You just have a bad vacuum line or switch. The mode selector switch in the dash controls which flappers get pulled. Either one of these is leaking or the flapper itself is sticking. I don't think there's any way to figure out the problem without tearing into things under the dash.
  3. GMMANIAC
    GMMANIAC Registered Member
    May 1, 2002
    53
    San Antonio, Tx.
    Check the vacuum line in the engine compartment for leaks, it is at the back of intake buy the firewall.
