A/C wiring problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cdh, May 20, 2003.
  1. cdh
    cdh Registered Member
    May 6, 2002
    69
    Gilbert, Arizona
    This weekend I was replacing the heater hoses on my 89 blazer and I somehow pulled a wire off it's connection and I cannot find where it goes. It is the single black wire that splits out of the harness right by the blower motor. I am pretty sure the wire is important because I don't have the high setting on the blower anymore and it is over 100 degrees outside. Thanks for the help.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    look for a connector on the a/c box that is missing a wire...i know its not much help, but i believe it goes to the blower motor speed resistor
  3. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    Look around the blower motor mounting flange for a spade terminal held on by a blower motor mounting screw. That should/could be where it came from. Sometimes GM ran a blower motor noise supressor inline to the blower motor power feed wire, and it had a black wire on it (sometimes), but more than likely (especially if your blower motor still has its power wire hooked up), it will be your blower motor ground wire. If not, check to see if you have an open terminal on your blower relay, but in '89 all the wires should be in one connector.
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    With it being a single wire, odds are pretty good it goes to the blower motor.
  5. Erich_in_AZ
    Erich_in_AZ 1/2 ton status
    Mar 23, 2002
    237
    Tucson (it\'s a Dry heat), AZ
    Do you have a 'low' speed? If you do, but just not high, look for a little rectangular box with some wires plugged in to it right near there. Sounds like you might have pulled it off the relay
  6. cdh
    May 6, 2002
    69
    Gilbert, Arizona
    I checked the relay on the side of the A/C box and it is not missing any wires. I think that there are two relays on my truck, one for the the high speed and one for the lower speeds. Is this correct? If so where is the second relay?
    If the mystery wire is a ground wire, should I just ground it to a bolt on the blower motor, and see it that gives me high speed on the blower?
