a couple 6.2 questions
Discussion in '1982-Present GM Diesel' started by g_mo, Jul 3, 2005.
  1. g_mo
    g_mo 1/2 ton status
    Dec 28, 2004
    131
    tx
    i've aquired an 82 6.2. i don't know the milage on the motor. i pulled the oil pan, there is no sludge in the bottom end and there is still cross hatch in the cylinders. what else should i look for to determine if it needs rebuilding before i swap it in my truck? i'm running a 350/465 now. can i use the same flywheel and clutch with the 6.2?
  2. tRustyK5
    Jul 23, 2000
    36,188
    1,393
    E-town baby!
    Do a compression test if it makes you feel better...however if you can still see crosshatching in the cylinders and no other problems it's probably in good shape.
    The 6.2 uses it's own flywheel, you see them come up on eBay often enough.
    I'm somewhat sure the pressure plate and clutch disc are the same as what is found on the 350's. You could find that out at a parts store for sure though. My 6.2 donor came with a flywheel, pressure plate and clutch disc already...so I used them.
    Rene
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    One thing I would replace weather it needs it or not is the timing chain set. They take a beating with the diesel. A full gear drive timing set would be even better, but a little spendy.
