A couple of questions about U-bolts
Discussion in 'The Garage' started by Shaggy, Nov 25, 2002.
  1. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> OK, a couple questions on U-bolts.
    #1 - I couldn't find Grade 8 nylock nuts, would regular nuts with high strength loctite be a good alternative or should I keep looking for nylock ones?
    #2 - I had some U-bolts made for the 14 bolt, but the guy bent them a little on the big side. There is a little bit of play when I put them on the axle, they aren't a real snug fit. When I bottom them out (just holding them there, no tension on them) they are about 1/4" too wide. Is that going to be a problem? If so I'm going to have to shell out another $50 for another set. /forums/images/graemlins/angryfire.gif
    #3 - I can't find grade 8 studs to use on the D60 passenger side perch. I know that Superlift makes a set, but they aren't long enough to use with the 0 rates. I'm thinking of using bolts with a set of spherical washers. For those that don't know about these, it's a set of two washers, each has one flat side and one side that's convex or concave so they equalize the load on the head of the bolt. This should make up for the difference of angle on the spring plate compared to the perch. Anybody see any problems with this? Should I keep looking for studs?</font color>
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    #1 - Everyone runs just normal grade 8 nuts on u-bolts. But there taller than normal nuts so they have more thread contact area for more torque holding power. You can use lock nuts I guess if you want.
    #2 - The 1/4" may not be a problem holding the axle but the spring plates aren't really made for this extra 1/8" on each side and you may have problems getting the u-bolts through the holes.
    #3 - I would think grade 8 bolts would work fine for this. But thats just me...
    Now why aren't you answering my messages on icq???
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    All studs are grade 8. Why not just order the U-bolts you need from 4WPW, when I purchased mine they had them in stock and they were the correct size.
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I am running 9/16" U-bolts (yours are probably 5/8 stock) and stock nuts on them and i have no problems. Once a month or so (or before wheeling trips) i re-torque all my nuts and bolts in the suspension, so i don't think it is a big deal. Driving my Junk around, i haven't lost the rear end yet /forums/images/graemlins/smirk.gif
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> OK, let me rephrase. I can't find ANY studs that are the right size. I thought that I came up with some today but they weren't long enough.
    As for the u-bolts, I know that I could have gotten them from 4WPW, but I refuse to give them any business. I've been screwed by them before and I won't let it happen again. I realize that u-bolts are pretty simple, but a man has to have his principles. /forums/images/graemlins/thumb.gif
    Thanks for the help guys, I guess I'll keep looking for studs and won't worry about the nuts.
    On an unrelated note, I found the perfect rubber hoses to use for the 14 bolt disc conversion, I'll make another post about them and add the part number to the disc brake thread. </font color>
  6. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I just went to 4WP today in Oakland looking for D60 Ubolts. They didn't have them, I know they have them but they wouldn't sell them separate from the lift kit! They also wouldn't give me Ubolts for a 14b unless I bought the whole block kit. I'm just going to have them made.
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    have you given Stephan a call? If ORD makes the zero rates, i figure Dr. Watson will know what studs to use with it /forums/images/graemlins/confused.gif
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Evan, if you can get a number or link to ARP (yeah, the nut &amp; bolt place), they should gladly help you with whatever specs and dimensions of studs you need.
    ARP would be the best bet since their studs and bolts have higher ratings for strength. Just tell them what you are looking for and chances are, they may have exactly what you need or can make it. /forums/images/graemlins/thumb.gif
  9. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Geez, I don't even want to think about how much a custom ARP stud would cost... I looked through their website and didn't have any luck. I may try to call Stephen tomorrow. </font color>
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I just posted this info on another post that Rod made. I bought my D60 U-bolts from ORD. They are part #GU37051. They sent me 3 U-bolts and the 2 bolts for the passenger side. My spring pack is about 2" thick and I think that most spring packs are close to that. Just tell Steve how thick your spring pack is and he will know what to send you.
  11. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yeah, hindsight is 20/20. I would have ordered them from Stephen but I thought it would be easier to just get them made locally. I was very wrong... /forums/images/graemlins/frown.gif </font color>
