A couple questions
Discussion in 'The Garage' started by 82_k5, Aug 22, 2005.
  1. 82_k5
    82_k5 Registered Member
    Oct 3, 2003
    94
    #1-What year 14 bolts would be a direct bolt in to an 82 k5 if any? I will probably keep stock springs, will the half ton ones work or should I use the heavier ones off the original truck?
    #2-My truck smokes blue out of one side (dual exhaust) almost all the time and the other side only on start up. Would that most likely be rings, valves, or what?
    Thanks a lot, I'll probably end up taking the motor out and freshening it up while I put in a new axle. Is there somewhere I can look for what to replace while the motor is disassembled?
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    14 bolt from any 3/4 ton will fit right in
    not 1 ton
    this goes for all 73-up k5s and trucks and burbs
    smoke all the time might be rings yes btu it can also be toasted valve stem seals maybe
    when you yank the PVC valve out of the valve cover is there smokey gassy air being pushed out of the hole with some pressure ?(put end of an index card overt he holew see if it lifts it up pushing gases out of the engine)
    if it does then im afraid probably rings are leaking past/worn
    but it is hard to say without seeing hearing
    make sure your pvc system is all connected and correctly
    needs to have filtered return(pass side valve cover) and pvc valve in driver side cover and conected directly to intake or to carb base assembly
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    3/4 ton 14 bolt is a SF. Get the SRW 14bff and have someone weld on new spring perches. Stronger better axle and the spring perches should be the only change.
  4. 82_k5
    Oct 3, 2003
    94
    So can I use my stock 1/2 springs or can will they have trouble controlling the heavy 14 bolt?
  5. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I thought some 3/4 tons had 14ff....... my K20 has the 14 bolt that has hubs that stick out with bolts on them, is that not a ff?
  6. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    My 14bff is from a 3/4 ton 4x4 truck and the shocks and spring perches line up perfectly.
  7. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    most all older 3/4 ton pick up trucks had 14 ff. SF came in vans and late model 6lug 2500 trucks i believe. pull of hub cap and look for eight bolts holding axle flange to hub/drum
    all 3/4 ton ff will bolt in, 1 ton requires perch relocate
  8. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Yes, you can reuse the stock 1/2 ton springs, I DID, and mine is a 14BFF from a '76 2wd chassis cab truck. :waytogo:
    you WILL however, have to get a different U-joint, it's a conversion joint to go from the 1/2 ton driveshaft, to the 3/4 ton flange on the diff. Napa has them for like $45 or so. I do not know right off the exact part number, been awhile since i have changed it. It DID have a unit from Autozone at first, but fried that one in like 6 months, try to stay away.
  9. 82_k5
    Oct 3, 2003
    94
    Will my brake booster and master cylinder be big enough for the bigger brakes?
  10. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    should be fine, i have done a few 1/2 ton to 3/4 ton axle swaps and if the booster/MC are in good condition then they have worked great with the new setup
  11. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    keep in mind the 14ff is an 8 lug axle, so if you don't change the front axle (or convert it to 8 bolt pattern) you will need two spares
  12. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Mine worked, but they tended to want to lock up the rear brakes first, i always thought it had something to do with the larger brake shoe surface area as compared to the stock little 11x2.5 or so brake shoes, mine on the 14bff with drums were the large 13x3.5 shoes.
    Didn't like it too much when wheelin, as i said they wanted to lock up on me, now i have disks, and love them.
    But to get you rollin, yes, it will work. I recommend going to an empty parking lot or side street, and testing the braking power after the install, so you can see for yourself if there is a drastic change, rather than finding out as a suprise when you have to stop due to traffic conditions.
  13. cbbr
    Jul 17, 2004
    14,681
    What year did they go to the 14bsf?
