a different hummer wheel ?
Discussion in 'The Garage' started by Jeromy Gibson, Jan 19, 2004.
  1. Jeromy Gibson
    Jeromy Gibson 1/2 ton status
    Apr 17, 2003
    127
    Amarillo Texas
    Long time listener, first time poster........
    OK I have been watching for a while and trying to figure out how to be as cheap as possible: and my question is has anyone tried to mount a hummer wheel backward on a D70.
    I can find 1 ton dually axle around here fairly cheap and wondered if it would work.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    what would you do up front then?
  3. Jeromy Gibson
    Apr 17, 2003
    127
    Amarillo Texas
    just run a dually D60 with the wheel mount correctly.
  4. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    There was a discussion on this a while back on Pirate. Best solution might be to look for a set of Dually rings in order for you lug nuts to have a surface to seat.
  5. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    I guess I don't understand what you are trying to do because these are the spec's I've been able to dig up on those two axles and those wheels:
    Dually D60: WMS to WMS is 76-5/8"
    D70 Dually rear end: WMS to WMS for it was 74-5/8".
    Hummer Rims: 16.5" x 8.25" w/ BS 6.75"
    Why do you want to run the rim backwards on the rear?
    Then the rear wheels will stick out farther than the fronts, assuming the numbers I've got are correct.
    I'm currious about what your trying to accomplish because I'm working on getting a D70HD right now for my truck and was gonna go with the D60 dually in the front too. But I was gonna run a custom set of dual beadlocks with Hummer offset and a 1" spacer in the rear to even up my track width.
  6. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I made up some spacers to do what your wanting to do, on your dana70 I think you can run some 2"inch wide spacers to get thinks right...
  7. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    A cab and chassis 14FF is 63.5 wms to wms, it might work better than a DRW pickup axle.
  8. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    What about running a dully front 60 hubs? I have some for sale. That is the way some are going I thought /forums/images/graemlins/confused.gif
  9. Jeromy Gibson
    Apr 17, 2003
    127
    Amarillo Texas
    I was under the impression that a D70 was narrower than a 14bolt. I am just trying to avoid running spacers and wandered if that would be an option.
  10. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    A D70HD from a chevy dually pick up is a quick source for one with the wide WMS (74"+ as previously stated) . Cab & chassis trucks use the narrow 14 bolts and D70's.
  11. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Is the search working on here again? If it is, search on here, we've talked about it a few times. Pirate, too.
  12. Jeromy Gibson
    Apr 17, 2003
    127
    Amarillo Texas
    Thanks guys
