A dumb question???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chaka73, May 3, 2000.
  1. chaka73
    chaka73 1/2 ton status
    377
    Southern California
    Can I swap the frame from a regular pick up truck 4wd 1/2 ton into my Blazer, will it bolt on with out any mods.
    LOVE MY GREEN GIANT!!!
  2. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    Nope the frame on a truck is too long , Sorry .
  3. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Your question brought up something I've been thinking about for a while. The 1 ton frames are made of thicker metal, so I've heard. Also, I have a friend that made a Ford diesel long bed into a short bed by cutting the proper amount out of the frame. (In doing so making a truck that Ford didn't produce for another 4 yrs) So I'm thinking a 1ton 4x4 frame shorted by 'x' inches would make an excellent K5 frame. (think steering box) I'm sure a few brackets and what not would need removed and/or added but other than that and some high tolerance measuring, can anybody tell me why this would not be feasible???? I'm answering yes you can, to chaka73's question, but am not positive. I don't do much if any rock crawling so a flexible frame is not important to me.
    Mud is just thick water, or is it that water is just thin mud?
  4. jmpd
    jmpd 1/2 ton status
    Mar 12, 2000
    181
    Mesa, AZ
    My buddy took an 87 crewcab longbed chevy non-dually. Shortened the frame behind the cab and made a crewcab short bed, lowered, I don't know about the alignment of the K5 on an short box truck frame. Do some measuring. Remember measure twice, cut once, you will have to re-enforce the frame and might want to box the area you cut
  5. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Wont work on the 69 to 72 blazer The frame is so defrent that on the blazer the bumpers bolt right to the frame not to brackets. plus the shape is defrent from the rear of the front spring to the front of the rear spring. on the 73 and up I think the rail taper going from front to back on blazers and not on the truck, theres also a change in the blazer frame when the rear set foot well was started.
