A few engine problems
Discussion in 'The Garage' started by pomai, Apr 27, 2007.
  1. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    Got the engine running. But it gets hot fast, just over 210 degrees & then I shut it off. But the engine, radiator & hoses just don't feel that hot. The electric fans don't even come on unless I over ride them & they are set at its lowest setting of 160 degrees
    Could there be an air pocked in the motor, not allowing the water to fully circulate thru out the motor?
    When I disconnected the EST wire to time it the engine just did not want to run, and had a difficult time restarting it & keeping it running.
    Do I disconnect the EST wire before starting it or during idling?
    I removed the spark plugs and they were all black, kind of an oily black, I couldn't wipe it off. They all look the same.
    I used NKGR V-power UR5 spark plugs, Should I be using a different plug?
    Engine is a late model factory roller 4 blt main block. 383 rotating assembly, scat crank & 6" rods, Probe forged pistons. World S/R Torquer heads.Cam is a Comp Cam # CCA-08-302-8, Lift .480/.480, Duration 264/274, Lobe Separation 112.
    Thanks, Ed
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    134
    Sounds like the thermostat isn't opening. Try letting the motor get just a little hotter and see if the thermostat will open. Or you can just replace the thermostat, they are kinda notorious for being bad out of the box.
  3. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    I always drill a .125 hole in my thermostat to prevent thermal shock. In addition it'll provide some flow regardless of what the thermo decides to do.
    Maybe get a infrared thermo gun to check things out. they have many uses.
  4. pomai
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    What is thermal shock?
    Thanks, Ed
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    X2.....
    I thought the hole was to allow air to bleed out??
  6. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    It also allows for a small amount of coolant to flow constantly through the system so that when engine temp gets up to 180-200 and the thermo opens and sends the hot coolant into the radiator, thereby allowing the cold coolant to go through the engine and thermally shocking the block and heads. If you have rapid responding guages, you can watch this happen on the guage, the engine temp will rise to about 210 (depending on the thermo. you have) then it will quickly drop to less than 150, and may do it a few times with less swing in temp each time before engine temp stabilizes. By having the bypass hole in it, it does a more gradual drop when the thermo opens, and eliminates the cycling. Especially on thinner castings which were more prone to cracking, this could make a difference in longevity.
  7. readymix
    May 30, 2004
    6,706
    26
    OK, I get it now. Never thought of it like that before. I have the hole in mine and my gauges do just like you say. Tops out at about 210 then rapidly drops to 160 (takes about 2 seconds)
    Then it will settle out at about 190.
    I hope it does shock the motor to death. It has 235,000 on it so far.
