A few question an new Chevy truck
Discussion in 'The Garage' started by CHEVY 4WD, Aug 27, 2004.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    These question are for a 99+ 2WD Chevrolet 1500 style truck
    Will a NP 208 fit on the back of the 4L60E
    How much are the frame rails in the front differnt from a 2wd and 4wd
    and has anyone EVER seen a SFA done on a 2WD of around that year truck?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    All the SFA swaps I see on the streets here ( yet to see one wheeling /forums/images/graemlins/dunno.gif ) use the existing case , and a drivers side pumpkin solid axle . I would assume it would bolt to the transmission , as its just an electronic th700 . What are you doing here , swapping to an older chevy style axle ? /forums/images/graemlins/k5.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A transfer case is not going to bolt to a 2wd tranny without a tailshaft swap.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    DUH , I must've overlooked that . /forums/images/graemlins/doah.gif Trade it in then and SFA an already 4wd truck , much easier /forums/images/graemlins/thumb.gif
  5. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    how hard is it to swap a tail shaft?
    can you use a 700R4 tail shaft?
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Trans must be completely torn down.
    I would imagine a 700R4 tailshaft from a 4wd would work fine.
  7. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Does the 99+ model use torsion bars or coil springs on the front?
  8. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    his is 2wd, so it'd be coil springs, correct?
  9. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] I believe 99 yes but very recently(somewhere since 99) they went torsion bar on 2wds as well. As Tim said, changing the tailshaft requires pretty much complete disassembly of the trans. As for whether a 700R4 one will work /forums/images/graemlins/dunno.gif. Don't worry about puting a driver side axle or Tcase in. The reason that is mainly done is on stock 4x4s thats how the tcase is. Why would you have to do it that way if you don't have a driver side tcase to begin with? Lastly there is one thing I always like to mention to people considering SFA swaps, $$$. They aren't cheap, many people think they will just slap an axle and be all cool, but there is more involved that just makes the money add up.
  10. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Buy a divorsed t-case that way you dont have to change trannys. Ford used alot of divorsed t-cases. Just use a ford axle with chevy outers for the same bolt pattern.
    Dan
  11. Grim-Reaper
    7,385
    Atlanta
    Sell the truck and buy another it would be cheaper.
    On the older truck to go from 2wd-4wd means swaping the crossmember that holds the engine. I bet it willbe the same with that to get the clearence needed for the front diff. Your talking about rebuilding the whole front of the truck. It would be easier to start with a 4x4 because the cross member will already be usable for the solid axle AND you already have working transfer case and the works. Then run a Hi pinion D44 or D60 from a 77-79 Ford. Swap the knuckes on the D44 to get the chevy lug pattern.
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    its actually not easy or almost impossible to switch the crossmember in a newer 2wd pickup. I know that is so on the 89-98 models. The front frames are fully formed boxed steel, there is no bolted or riveted in crossmember to be replaced.
