A few questions for manual swap for diesel
Discussion in '1982-Present GM Diesel' started by protechk5, Jan 2, 2007.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    So Im swaping in a 465/205 in place of my 400/208. Im getting everything from my old high school auto tech teacher. The only thing I need is a diesel flywheel I believe. I did a search but didnt come up with any part numbers, do I just use one off a 6.5? Also what do I do with the old vacuum line from the th400? Any other things that I should be prepared for? It should be pretty straight forward since he has everything I need. Also I just going with manual clutch linkage for now. Also how do I find the wire for the back up lights? I plan on leaving my auto cloum.
  2. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
    Just remember to get the old trans oil out of the radiator. Other wise when you going down road and heat it up it will ooze out and all over the motor and trans.
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    6.2 and 6.5L both use the same flywheel. They are getting hard to find.
    As far as the TH400 vacuum line goes... plug it. Not very difficult to do the conversion if you get all the parts from one place.
  4. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    Don't forget the later 6.5's used the dual mass flywheel which is supposed to be a POS.
    Rene
  5. kennyw
    Jun 9, 2002
    13,223
    94
    Thats true... I don't know what year the dual mass flywheel was started though. The one I have is the early single mass from a 6.2L.
  6. protechk5
    Sep 26, 2004
    2,015
    VA
    pm sent
  7. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    Picked up flywheel today. Guy who sold it wasn't sure that it is from diesel, he was told from wrecking yard that it should be from diesel.
    Besides the rust, it in good condition. I found this casting number from it; 1405025N. Did google it, and based on that it is from 6.2, non dual mass.
    Why dual mass sucks?
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Because it seperates and gets off balance.
    A lot of car manufacturers at some point experimented with dual mass flywheels and they all so far have realized their mistakes.
    I don't know the reasoning behind doing it in the first place :rolleyes:
  9. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    If you don't have a core and want to get a good new flywheel, go with a Luk LFW-201. I sent an email to Luk customer service (Schaeffler is their parent company), and a guy emailed me back with the name of a local distributor. Ended up being about $180, which I don't consider bad for a new flywheel without core.
