a few suspension questions ?
Discussion in 'The Garage' started by BL1TZKRIEG, Jul 28, 2005.
  1. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    I was thinking about doing a 4" shackle flip and get rid of my blocks
    I want to replace the old springs "their stock height" with new ones
    whats a good place to get new stock rear leaf springs? jc whitney has some are they any good?
    if I get new rear springs when I do the shakle flip will I need to get some zero rates or will it be high enough
    also my slip yoke sticks out just a little over 3 1/2" is that to much? how far are the suppost to stick out?
  2. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    I assume you have 4" lift w/blocks in rear. With old stock springs, you never know where it's going to sit until you lower the truck onto the axles. My truck sat perfectly level on the stock springs, installed 4" Tuff countrys all around (HD in front) and the rear sat 3" lower then the front. Had to put in a helper and a zero rate to level the thing.
    I suggest you do the shackle flip, use your existing springs to see where it's going to sit. And then figure out how many inches your going to need. Instead of stock springs, you could use a 2" lift spring/zero rate combo or go with new stock springs and hope their not saggy. You will get a better ride with stock springs. Then see where it sits again. LMC Trucks sell stock springs also. Not sure of price though.
    It stinks, not sure if I helped at all, but trying to keep you from spending unessessary cash with a little tweeking and planning.
    Don't know about the slip yoke. Sorry.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I did the shackle flip and a zero rate on the back, 5" springs up front, and I need about another 1" of lift in my saggy rear.
  4. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    thanks a lot for the suggestions
    yes I have 4" springs up front and 5 1/2" blocks in the back :doah:
    it sits perfect now accept for the passenger side leaf being sagged out. thats why I need new springs cause it leans to one side.
  5. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
  6. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    look in the yellow pages of your phone book and find a spring shop in your area for stock style springs. i can get them in my area for about 100 bucks per pack. 5 leaf with over load also. 52" rears. and if you want to do poly bushings thay can press out the stock style rubber bushings a lot easyer than you can. and thay will have all kinds of bolts and ubolts made to fit in stock for ya so you dont need to run around all over for stuff. good luck.
  7. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i just posted my lDIY4x flipshacke with stock leafs ,finished last night.
  8. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    thanks for the replies
    anybody know how far the slip yoke is supposed to stick out ?
    is 3 1/2" too much, how far does it stick out stock?
