A fix for a stubburn swaybar
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Apr 25, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Here's the deal. The last couple of times I've disconnected the sway bar (using ORD's disconnects) It's been difficult to get the swaybar to move up or down. I have new bushings at the pivot points that I installed about a month ago (that mount the swaybar to the frame)... My question is there a company that sell greasable brackets for the two pivot points?
  2. dyeager535
    26,979
    I know on various other suspension bushings, when poly is used (yuck) if they aren't already present, people drill the bushing (and bracket in your case) for a zerk fitting.
    I know rubber and oil don't really mix, not sure if that holds true for grease and rubber though. (maybe synthetic grease?)
  3. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Yes, get them from Energy Suspension! I had the same problem and went and bought the greasable bushings from Energy and they work awesome! It slides up and down with the touch of a finger with the greasable ones! /forums/images/icons/smile.gif
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I was having the same problem awhile back, but will never have it again. I disconnected it before my last trail ride, and couldn't hardly get it to move. So I got under it and bench pressed it up as much as possible. Then I let the axle to the rest of the work to move it when I started flexing. After the ride, I drove home without it connected, and I didn't mind how the truck acted without the swaybar connected, so I sold the disconnect kit and ditched the swaybar. I haven't found any major side effects of removing the swaybar, except a little more nose diving during hard braking, and a little more body roll in corner. And that is all very managable. This is also with a soft 2.5" lift, if you have a higher, stiffer lift then you wouldn't even notice it as much as me.
  5. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I'm with Hoss... ditch the darn thing and get on with life! /forums/images/icons/laugh.gif You'll be just fine. Otherwise, check Grimmy's trail gear article. He suggested some tools in there just for what you are describing. /forums/images/icons/wink.gif
    -Dan
  6. kpanza
    Dec 8, 2000
    1,579
    I agree, the ride is not too wild without the swaybar. I didn't hardly use it either, and I sold the disconnects and greasable bushings also...with my new D60 and crossover, I can't run one anyway...no big deal. I will say that for mountain driving, the swaybar definitely helps!
    With the greasables, it's so easy to move it back and forth, that you might as well use it if you do a lot of highway driving and want the tightest ride available.
  7. UseYourBlinker
    Jun 7, 2000
    11,117
    Well I did a search and found the energy suspension ones,and instead of buying them I just drilled,and tapped a zerk fitting into the stock brackets. Also had to drill a hole in the bushing,but it works alot better. Only cost was the fitting's..at the local hardware store..
  8. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I was going to buy the energy suspension but figured it be easy enough to do the same thing, hell I'm so cheesy I took the zerks off old u joints hehehe.....
  9. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    yea just ditch the sway bar...mine rides just fine without it..been runnin without it since november.
  10. chevyfumes
    Feb 24, 2000
    38,584
    266
    I had mine off for 3 days after I installed my lift and I like it better with it on, ofcourse I'd do just about anything to stiffen up the steering on my Blazer...
