a good way to check if my frame is level??
Discussion in 'The Garage' started by down4thakrown, Jun 5, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    measure each end of the frame from the ground??? i dont have bumpers and the cab is bolt to the frame by the 2 front mounts and i know how i wanna do the rear mounts just need to make the frame and cab level, then :weld: in the rear mounts :pimp:.
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Big jack stands and a 4 foot level. Can't trust the ground or the suspension to be level...
    Put the level across the frame at the front, and use a pair of tall jack stands to keep it level. Then move to the rear and do the same.
    Rene
  3. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    thats a good idea to make sure its level side to side. but how bout front to back. i wanna make sure the frame is level so when i make the rear mounts. i got the front clip bolted on and theres no bed. just a cab with the front clip is all the sheet metal. thx for the info
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    The pick-up frame should have a flat section behind the cab. Set the level on there the other way and get it level too.
    Rene
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    its a k5 frame, theres a hump half way back that looks flat about 6inchs on top that might be enough for a level. you guys think it would read accurate right there?
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  7. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    thx that was a big help
